1 - 20 of 34 Posts
Its it any different between class AB and D amplifier for 12'' subwoofer. What is the pros and cons?
My subwoofer provide 250w RMS, should I get a 4 channel amp use 2 ch bridged(220w rms) at 4 ohm or get a monoblock with 250w rms at 4 ohm output. Which is better, if get 4channel amplifier, I still can use for 2 channel more.
Which is better way for subwoofer, class AB or D amp and bridged 2 channel output or monoblock?
At that's power level it is a wash.
At high power, even I would go Class-D.
So if you have an amp already, or find a cheap used one, then there should be a few at those power levels... in either Class-AB or D.
But if you are buying a the new Class-D makes sense, and probably somewhat higher power also makes sense.
Note: I have a 300W ([email protected]) Class-AB as a sub amp.
that mean for class D monoblock for subwoofer is more powerfull and reliable
Class D is more friendly on your electrical system at higher power but if I was only looking to provide 250-300 watts as you're intending to do then an A/b amp would do just fine.
I have a 4 ch amp but will use for 2 way front stage, I think I will go for class D monoblock for trunk subwoofer
One more questions, I saw some person load 4ohm to 2ohm and get high watt for subwoofer. What is the different betweem 4ohm and 2ohm
2ohm speakers have lower resistance than 4ohm speakers, so they draw more power from the amp. That's normally a good thing, especially for subs, but only if the amp can handle the ohm load. There a lots of different ways to wire subwoofers, and each will affect the ohm load at the amp.
This is the spec of amp that I plan to buy, how good is the subwoofer when running 2ohm
What subwoofer is it? You can't simply pick and choose if you want 4 ohms or 2 ohms, it will depend on the number of voice coils, and their impedance.
^Assuming there should be a question mark at the end?^
A 300w Class-AB is more puwerful than a 250W Class-D.
A 1000w Class-D would be more powerful than a 300w Class-A.
A content arguement for reliability can be made for a 15 year old Class-AB that works.
If you are headed to a new amp, then I would be looking at 500-1kW class-D
If you only need 250W, and have an existing amp or willing to get a used amp, then Class-AB makes sense. I would think a few people have lower power sub amps for sale?
That will make 400w into 2-ohms and 200w into 4-ohms...
And then at 4-ohms, the old 300w Class-AB has Personally I would rather have a 2x 4-ohm VC wired in parallel to 2-ohms... or run a 4-ohm sub.
But does it matter?
I think this is getting too complicated for a simple question. I don't think he cares about the sonic differences between Class AB and Class D.
Generally speaking, a Class D monoblock is the best choice for subs. If u have enough space in your vehicle, get 2 4ohm subs and wire them for a 2ohm load. That's how my system is set up. If u only want to run 1 sub, then get a DVC sub with 4ohm coils. The coils can then be wired to create a 2ohm load.
As people have said, class D is more power efficient, which means it won’t waste as much electricity as heat like a class A/B will. And class D can be smaller while still putting out good power.
But 250w is a small amp for a subwoofer, which is why it doesn’t matter much whether you go with class A/B or D.
if you were to get a high excursion subwoofer (>20mm) then I’d suggest more power but for a subwoofer under 20mm, 250w is a little low but should work fine.
How about this.. If you decide to go with a 2 ohm load get a Class D. If you go with a 4-ohm final load get a Ab amplifier.
Discussion Starter #15
But does it matter?
I didnt know my specs of subwoofer since I was keep for more than 5 year, but I thinks it was 200-300w rms at 4ohm.
I have a 4 channel AB amp for my front stage with 4x70rms, 2x220 bridged @4ohm.
Btw, what is the different between 4ohm and 2ohm, it is good? How to hook up
Discussion Starter #16
Ya, I want to run one sub only. Which is the best way for I run it and how it hook up
mohawk classic mc.124
Looks like that is a dual 4 ohm sub with dual voicecoil. You have two options for wiring it if that is indeed the correct configuration; 2 ohms or 8 ohms. If those are the choices, definitely wire it to 2 ohms. Look at Crutchfield subwoofer wiring diagrams to get the proper way to wire your sub to the amp.
Is it 2ohm sound will be better?
How are you defining better?
Loudness?
Distortion?
Something else?
They should about the in 1, 2 or 4 ohm.
Inthoery 4 or 8'ohm could sound better, but theory says it is still almost nothing one can hear.
Discussion Starter #20
Loudness?
Distortion?
Something else?
bass beat could be more deep, because I notice that when put a single sub in trunk at a sedan car, normally will listen bass is slow from rear
1 - 20 of 34 Posts
