Comparison of subwoofers for 2013 camaro
1027 Views 20 Replies 8 Participants Last post by  SomeGeoffGuy
Hey guys, I've got a 2013 camaro and I also have a memphis mojo 12, however the box is too large and I would need a custom box built, my question is which sub would be better for response/loudness between the memphis mojo 12 or the jl audio stealthbox with 3 10 inch subs
I would also like suggestions for good amplifiers for either one as well. I had a sundown audio sfb3000-d but due to a factory issue it fried itself. Would prefer not to go with sundown again. Thanks!
1 - 7 of 21 Posts
That stealth box is 2k$ 🤯, no.... your better of getting 2 SQLs and having a box made for them. I have my 2 SQLs on 4k, sealed 1.1cbft after displacement each. These things are loud AF and sound so good.
Ah, see I had already spent 2k on the previous install, the mojo 12 alon was 850 along with the 600$ amp, dynomat and everything, I don't mind the price tag as long as its easy to use and sounds good
Reactions: 1
Since you already have the MOJO, build a box for it, or buy a prefab sealed tester box to see if you like how it sounds in the camaro. I say sealed cuz your trunk is small.
Did you like the way it sounded? Or are you just looking for something different.
I liked how it sounded, but it will be a 2 hour one way drive to get a box made since my local shop got destroyed by a tornado, and the previous box broke my 6x9s, I can also sell it and use that to buy the 3 10s, it was very loud but I would like more sound quality, as long as it still hits low notes
I'm not sure if a prefab box would work for the mojo, that sub alone weighs over 50 lbs and it is just massive, the box i put in it would fit 2 normal 12 inch subs in it
They sell camaro boxes online, maybe a dual 12 box sealed for some SQLs. All you'll need is 1cbft sealed each and they will out perform the JLs in every way. And would cost you half the price. I'm sure them JLs are cool but I wouldn't put out 2k on shallow subs. But the SQLs require some decent power to get their full potential.
Just my opinion. The stealth box seems convenient though.
What is an sql?
i also found this option as well
never heard of the site but online reviews say its well known and good quality, i could buy that and put some full size 10 inch subs in it such as these
specifications check out pretty well, they should have enough air for each sub
12 inch subs even without the box are really pushing it on the height requirement, and the aftermarket 6x9s i have with the bigger magnet really doesnt help the matter, i think i may have to go with 10s either way
Reactions: 1
1 - 7 of 21 Posts
