Had a bit of time to get one more simple project done while we are working on two big projects.
This one was a bit of a unique situation as the customer already had a build started, but wanted to switch things up and utilize our experience in building sq cars, as well as our familiarity with the FT86 platform.
The previous install wasn't terrible, but being that we are so anal about what leaves our hands, we ended up taking everything back out and redoing the whole build...save for the main power cable
goals:
1. achieve a nice level of sound quality throughout
2. maintain the design from the previous install, namely, the amps under the seats and incorporate a DSP and wire for fully active power scheme.
3. keep a relatively low profile upfront.
the one part that is not fully complete with the build is that the customer is waiting on two custom fabbed side enclosures for the car, but the vendor has not yet shipped them, so currently, the car is rollowing with 2 JL audio 10w6v3s in a square dual chamber ealed enclosure in the trunk.
lets get started.
the signal starts with a kenwood DNN990HD double din unit, it is the newer generation of kenwood that is andriod enabled. i wish i had more time to play with it but was too busy working on the car hehe. it was previously installed, we simply cleaned up the wiring behind the dash a bit and reoganized things:
the system uses a mosconi 6ot8 DSP for tuning, so it can be programmed from the front seat via a BT enabled laptop:
the front stage consists of a set of Hybrid Audio Legatia three way compoents. the L6SE was installed into the stock location. The previous installer had soundproofed the outter door skin and inner door skin. we added a foam barrier to the outter door skin, some blackhole tiles to the outter skin, and also built a new spacer baffle match routed from the oem speaker, as the previous one was looking a bit ragged:
we also fully sound proofed the plastic door cars with STP gold damper:
the L3V2 midrange went into the stock location on top of the dash. borrowing a technique i saw from the ft86 forums, i first ground down the plastic on the bottom of the grille, and fabricated two mounting rings from black acrylic. this allows me to tap the holes so i can bolt the speakers in from the bottom:
the ring baffles were then secured to the grilles using HD plastic weld epoxy:
the l3v2s were then bolted in place with bolts, washers and lock washers:
and the entire panel was sound proofed. a piece of black foam was fit inside the tweeter hole and then sound proofed over so you cant see any random things through the empty grille:
then two midranges were then wired up and installed:
for the L1pro radiator tweeter, i went with A pillar mounting. having just recently completed a FR-S with A pillars, drawing from my past experience with this tweeter, as well as the csutomer desire to try and keep things low key, i went with off axis design that pushes the tweeter as far foward as possible, aimed high to minimze reflections off the shroud. from past experience this gets me a nice high stage and imaging with good center focus.
so here are the completed A pillars with the L1 tweeters:
a few build pics of the pillar pods.
first, the pillars were rough sanded, and then rings aimed and attached:
mold cloth was pulled, resin applied, allowed to cure, and then reinforced from the inside via the duraglass/resin mixture, and then any unneeded excess material trimmed off:
filler was then applied and the entire shape sanded smooth:
factory matching vinyl was then used to wrap the pillars:
and the hybrid tweeters installed:
a final look at the entire front stage:
goals:
lets get started.
