It states 120 watts rms per side. Still quite a bit of power considering that most ratings should be for the full response stated. Crossing upwards should increase mechanical limits though thermal will still be the same.I can't think of any speaker sets that give a total power rating. It's per side for components, so the Massive Audio rating of 250W RMS on the RK6 components means you want an amp that does 250x2 at 4 Ohms if matching power is your thing.
On the desription it actually states both per set and per side numbers as seen in the quote below. It is because of listings/descriptions like this one that I said to READ READ READ more then one site so that you can have a better chance of verifying the specs.Sonic has them right here Massive Audio RK 6 (RK6) 6.5" 2-Way RK Series Component Speakers.
The memphis bridged still doesnt sound like a bad idea though,
sonicelectronicx said:6-1/2" R Series 2-Way Car Speaker Component System
Power Handling:
- Peak: 1000 watts per set / 500 watts each side
- RMS: 240 watts per set / 120 watts each side
