1 - 13 of 13 Posts
Hi all I Want to make a ported box for my AA havoc 18's and tuned for the lows , for my van sizes of space are 54" wide X 19" deep 36" high is this enough ? Can be deeper i'f needed . I'm looking for hair tricks from these subs my vans a small fiat one :)
You might have better luck by posting this in the spl forum.
Just sayin
Give Ryan at Ram audio an email or Pete from PWK. They will design an enclosure for you. Yes it costs money ~20 for Ryan and ~50 for Pete. Odds are though it will be superior to what you will draft up yourself and make building the enclosure far easier.
DICE!
Box size looks sufficient.
Port size ?
Amplifier ?
I'm unsure on the port size :( , but I'm looking at running two Orion D5000 amplifiers one for each subwoofer . Would these be ok , or is there a better suited amplifier for these havoc 18's there 1250wrms each
OK, you have 2 of these subs. You are wanting to run them ported. You have these 2 amplifiers? Or you are looking to purchase amplifier/s to power these things?
Edit: went back and reread your initial post.
OK, you are wanting to do hairtricks.
Do you have the electrical to power 3 kilowatts +?
It is going to require moving lots of air. I would get a hold of Pete. Let him know that and figure out what amp you want.
I am a fan of Sundown but there are a ton of mono high power amplifiers out there. I would get a single amplifier. Easier to set up, less wire to run etc.
its not that hard. just find the specs and plug em in to a program like winISD. dont guess on the size and ports for a ported box. it will sound bad and wont handle power properly. dont forget that will also need to use a SSF to protect the subs.
I'm looking at Orion d5000 amps two of them one per sub I don't mind running twice the cables etc as long as it will work ok , I'm also going to uprate my alternator to a 250 amp one and get some red top batteries too . It's a very small cab in my van the cabs small and air space / movement should be quite nice .
Do you have a website for pete ? Or is he a user on here I'm in the Uk :) i'f he's in the US would he send plans across to the uk ?
pwkdesigns.com for pete.
Note than it can take a while after you submit your request (an online form). Apparently he gets a LOT of requests and is quite busy at it.
Awesome thanks mate !!
I will get in contact with him good things are well worth the wait :)
There are much better batteries than red tops. Not sure what's available in your area but there is better.
Discussion Starter #13
I thought they were the best , what kind of ones do you use in the US I might have to order some and ship over i'f there better quality , I want them to last a while
1 - 13 of 13 Posts
