1 - 5 of 5 Posts
I'm trying to figure out what i need to install a sony xav-ax1000 in my 2005 nissan altima. I've searched the internet, but i can't find much on connectors. I know there are four connectors, two of which are for audio and I have ordered a 70-7551 adapter for the rca connectors on the ax1000. that leaves two connectors with which i am lost. i would be grateful for any help, and if there might be a better forum for this issue.
Do you have an amplifier kit to connect the amp? Proper cables are needed. To get this going. Also you need a remote wire to the. On the amplifier. A d make sure you provide proper ohm load at the amplifier
Sent from my Pixel 4 XL using Tapatalk
here is what i have
2005 Nissan Altima double DIN dash kit
2005 Nissan Altima
Sony XAV AX1000
70-7551 Amplifier integration harness
Antenna adapter
i need to know what else i need for this installation or if i need different parts
I apologise I just seen you want to install a radio in your car .. my apologies I thought you want to add an amplifier..
In that case crucified website will be your best best. I'm not sure what wire harness you need ... I don't even have a radio in my car
1 - 5 of 5 Posts
