1 - 7 of 7 Posts
SS Reference 200, 300, (2) Class A 6.0 and a Phoenix Gold ZX500
3 way with midbass in back doors and 2 JLw6 oldschool.
Tell me how yall would set it up. (as far as amps)
Thanks!
I have a MS-8 for processing. I will def look for that thread when I get a minute. Thanks for the heads up.
What Im thinking as of now. In a 99 Tahoe:
Tweets: XT25 / Ref 200 - Upper door stock
Mids: HAT L6 / Class A 6.0 - Lower door stock
Midbass: Focal KBE 165 / Ref 300 - Bottom front corner of rear doors stock
Subs: (2) 12w6 at 1.5 ohm mono or 3 ohm x2 / Phoenix Gold ZX500
Processing: MS-8
Headunit. CDA-117
Leftovers: JL 300/2, Ref 200. (the second 6.0 fell through)
My two main points of confussion are; should I use the 6.0 or ZX500 for the subs. And if I use the ZX500. Should I use the 6.0 for mids or midbass with the 300 powering the other.
I know my rear door positioning for midbass isn't the best but I do a lot of traveling for my job and really need as stealth of an install as possible so I am not replacing windshields and equipment every couple of months. Im hoping with the help of the MS-8 I can pull it off.
If you don't mind would you go into a little detail on why you would set it up this way? I am wanting to learn everything I can before I start the actual install =)
Super Moderator
Actually I'll revise the list and explain.
You lack a sub amp. Sell what you don't use and buy an amp capable of 1000W at 1ohm.
JL 300/2 on midbass, the most power at 4ohms.
ZX500 on midrange, plenty of power.
Ref 300 on the tweeters, just because it has more power than the A 6.0.
I don't know an awful lot about the real world power or of the soundstream amps, but since you are not using them at low impedance and not bridged then I doubt it makes much difference between the 300 and A6.0. And which one has better sound reproduction, again I would make a guess they will both be plenty good.
EDITED, so re-read.
Discussion Starter · #7 ·
man and I thought car audio would be a breeze compared to my daily job as a network engineer lol
and thanks for taking the time to help out. I really appreciate yall on DIYMA
1 - 7 of 7 Posts
