1 - 2 of 2 Posts
Doge Neon
HU - Alpine CDE-172BT
Front Stage :
8" Beyma 8G40-4 in doors
Midrange and tweeters still to be decided. 3.5" Pioneer bullet tweeters in dash atm.
Sound Treatment:
Spectrum Sound Deadner sprayed on undercarriage
Front Doors treated thoroughly. Sealed and deadened as good as possible.
Car floor and trunk will be deadened and get CCF/MLV treatment.
Electrical:
Aftermarket 200 amp alternator
2 runs of 2/0 Royal Excelene welding wire run from hood to trunk
Big 3 with 2/0 Royal Excelene welding wire
At least 1 more battery will be mounted in the trunk area.
Amplifiers:
(2) PPI 140x4. The Beyma 8's will be running bridged off one and the midrange and tweeters off the other one.
Sundown SFB-3000D for the sub.
Goals:
Its a daily driver. Sound Quality Loud is the general goal.
Secondary goal would be for the sub to hit lows with authority.
Ideal situation for me would be if I can leave a 6" section on side of trunk open that I can still push long things through the pass through (corner bead, 2x4's, paint pole, etc.)
Questions:
Need help with choosing the right orientation for sub and port in a standard ported enclosure... position of box in trunk as well.
***If both firing to the rear, how much space do I really need between sub/port and rear of trunk?
***Is there a situation that could work where I build all the way to rear of trunk and have sub firing sideways into corner of trunk where there is a cutout with some space there? Maybe the port would fire up into the lid in this situation?
***Maybe downfiring sub into empty spare tire well is option?
If pic doesnt load, dimensions are...
19"h x 24"d x 26"w. Or try this link
https://drive.google.com/file/d/14sxbMoLyVKL5f3-p9g-oUGAp3-RWikhB/view?usp=drivesdk
The pic below shows dimensions that I could work with and totals close to 7 cubes gross. My problem is if my box and port is firing to the rear, I think the box should be pulled 6"-12" off the rear wall to give some space for it to fire into.
If I subtract 12" from this depth, I only have a box that's 12" deep about 3.4 cubes gross... (gross). I'd really like to hit close to 4 cubes net on this build so I could get a 15" ZCON in there. I'm fine with building in the trunk.
1 - 2 of 2 Posts
