1 - 8 of 8 Posts
I have an Acura 2007 TL, I'm using the factory head unit. I use a Matt R line driver to feed the my DSP6. the DSP feed my TRU 4100S & 2200S amps, the 4100 is the amp that runs my PHASS Midrange & Tweeters, most would call them both tweeters, my issue is the factory h/u puts out 1 volt full volume, so the line driver boost's the signal. Almost on any audio passage where output is increasing and output is getting complex I get this cracking noise. I get a crackling sound from the mid or tweeter. Both drivers are fine, taken out and tested, and the mid bass shows no sign of this artifact.
Is the line driver over loading the DSP with to much output? I'm lost......
1) could be the HU is maxing out
2) the line driver could be maxing out. does it have an input and output adjustment?
3) could be overdriving the input to the amplifiers (how did you match them?)
4) could be the crossover points. I heard tweeters crackle like that when crossed over too low.
I just spent 30 min on the phone with Zapco,
I only running one input into the DSP 6, I need to run all the inputs in, for the outputs I m I'm using, The output signal is way to hot for my Sweet Little PHASS Driver.
My output wasnt equally to my inputs
glad you got it figured out :p
sweet! I was gonna suggest you talk to Matt directly about it too :)
So, I add all 3 inputs, adjust the sensitivity, Start @ 0db output.
Select all the correct settings - AND PRESTO !!!
I have a NEW system, Man it came to Life - FINALLY !!! ITS SICK !!!
BUZZMAN - I LOVE YOU - DUDE !!!
All the help you've given me and your support with my system, its here.
And its Awesome !!!
And its Awesome !!!
You are welcome! I am so happy it all got resolved. Now, I just need to get my mitts on the system for one more extended tuning session. :)
Nice I would have to get a good listen to your system again..im close to get mines dialed in =)
and waiting for Buzzman to perfect it lol
1 - 8 of 8 Posts
