1 - 2 of 2 Posts
So I recently got a jbl ms-8 in my 2003 Volvo v70 wagon. I've been looking into a center speaker so I can use the logic sevens full benefits. There is no stock speaker but I don't mind a custom install, and I just have some things I need clarified? First, do I need to create a center off the fronts, or can I just run the center speaker once I install one to the ms-8 and label it as a center and just let it do it's thing? And lastly what kind of speaker should I use for the center, I'm guessing a tweeter? Thanks
Ideally, you want to match your left and right speakers. The MS-8 creates the center signal, so it's just a matter of assigning an output channel as the center and making the necessary connections.
If you can't fit the same style/size speaker, then a decent wideband driver or small co-ax might suffice.
1 - 2 of 2 Posts
