guys , i thought i would share some of the items i use for my garage set up .
these are main items i use for testing and comparing .....
the most important ...... power supply .
hawker battery .. 12105f weighs in at 101.4 lbs
as a back up a a optima 5.5
also a vibe 50amp constant power supply ..
i have never needed to use the optima or the vibe power supply as the hawker has taken everything i trow at it , sometimes 6/7 large amps running at once ......
i use a trickle charger to keep it fully charged ,which i disconnect when listening/testing .
i have 7 vibe fast plugs connected the the hawker . allows for easy and fast connecting of amps etc.
some other items i use a lot are a source switch , great for comparing heads units side by side , i use the same cd in the head units ,same amp and same speakers and the switch to flip between ,,,
you can also connect the switch backwards to compare amps side by side from the same head unit
the speaker switch ( on the right ) makes it easy to compare sets of speakers side by side from one amp or head unit ....
something else i have is two pairs of the same speakers , i use when comparing amps side by side . one set connected to each amp and use the audio switch to flip between them ..
some things i use are a active alpine x-over ,allows me 4 way control
i use a kenwood 1023 as my reference amp .
rated @ 2x 200w rms and 1x 600w rms ,, this actually pumps out over 800w rms @4ohms mono , a fantastic sub amp as well a great sq amp .
and some genesis amps (SM60's & B40's) for components and active use
all my testing and comparing is for my own pleasure /fun , nothing scientific about it ..
check out some of the toys i have been recently playing with ..
http://www.diymobileaudio.com/forum...dio.com/forum/diyma-sq-forum-technical-advanced/108149-ghetto-garage-setup.html
