I started off with an OEM JBL premium sound system in a 2011 Prius. I replaced the head unit with a Joying to get CarPlay, but that just threw me down a rabbit hole when I discovered how tightly integrated the whole JBL system is and I couldn’t get a proper sound from the factory amp with the Joying’s line output (super low line output voltage).
I ended up with a JBL DSP4086 amp/processor to take advantage of the high-level inputs and some Infinity Reference 3 1/2”co-axial speakers to replace the factory dash drivers. I now have it all installed but am confused on how to set my crossovers for the new dash drivers that theoretically should have a wider range than the OEM.
Infinity claims the speakers go as low as 85hz but they also say:
I don’t currently have a microphone to do advanced measurements. Thanks for any feedback or education on this matter!
So if I’m reading this correctly, the capacitor is high-passing the speaker to 196hz at 6db/octave, correct? Would I be best to leave the capacitor in place and try to match this point with the door 6x9” mid-bass drivers? Would I be better off removing the capacitor and dial in a different frequency with the amps active crossover?Crossover: The included 270 microfarad capacitors are 1st order high pass crossovers (6 dB/octave); the crossover point is approximately 196 Hz. One capacitor is wired in-line with the positive input of each speaker. For best results, solder speaker wire terminated with quick slides to both ends of the capacitor, then insulate the assembly.
