The diameter in the table below is diameter at the surround midpoint, so a 6.5 mid is actually ~5" in the table below. Ideally you stay below the orange column, but it's more a concern of where your tweeter is high passed at. A lot of component kits don't low pass the woofer, they just let it roll off naturally. If your tweeter is high passed lower than the orange column, you're good-to-go...
www.diymobileaudio.com
TLDR: 2500 hz
Help me avoid beaming my tweeters
Hey everyone. So i currently have Hertz ml165 midbass Hertz ml700 modrange And hertz ml28.3 tweeters The 700s and tweeters are almost 90 degrees off axis in the a pillars aimed at each other across the dashboard. Midrange currently at 500-3500hz and the tweeters obviously taking over from...
TLDR: 2500 hz
