1 - 3 of 3 Posts
I just installed a new Fosgate P3 15 in my wife's car with an Orion HP2800 amp. At what frequencies do I set the LP and the HP. I believe each setting is 50-500. The enclosure is vented and is to be tuned @ 32hz. The dual VC is ran in series and is bridged to the amp.I also have an Alpine HU where I can adjust the Bass frequency as well as the HPF settings for those. Also, on the HU, I'm trying to figure out how to change the Q or SPL(it's stuck at 1) Any help would be appreciated. Thanks.
For the HP, i wouldn't set it that high. It has to go lower than 50. If it doesn't you can probably turn it off.
For the LP: you set this based on your mids. 100 or lower is a good rule of thumb. If you have crap for midbass maybe go a little higher.
Blue Collar Audiophile
When in the eq menu push the upper left of the 4 colored buttons to change the q of the eq band. In the crossover menu you want the sub crossed with a 24db slope (4 is the number that slope is identified in an alpine).
1 - 3 of 3 Posts
