The current Alpine 7", 8", and 9" AV units are the only thing that I know of currently having digital (toslink) out.
There's probably a few, and at least one. Though likely all old school stuff.I don't know of any Car Audio components which used a coaxial digital output. That being said, in this case I don't see value in it. The DSP section of the DSP Pro operates in 24bit/96khz max. Anything above that will be downsampled in order for the DSP to process the signal.
Yeah, it would be quite strange if that were true. CDs are 44100Hz... CDs aren't the only thing that people listen to but one might think that rate would be supported...Only accepts 48kHz? Thats strange.
...or wait for Sony Hi-Res HU:Currently the big hole in the market.. Which is bad because folks have to improvise, but good because folks are improvising.Tablet installs on the rise, and other signal converters being tried with much success to feed DSP's. Reason I'm in defiance and revolting against the head unit makers and doing an iPad build in the truck, whenever I ever get around to it, with some wired method or maybe wireless.. Depends on what's out by then for digital signal options. But the doggone tablet (iPad in my case) will do anything and everything a crazy head unit will do, except play a disk or have a sure-enough local radio tuner.
I should add, if you can do a 2-din, there is the option possibly of an E3io (PC-based) head unit, with whatever output you can have them hang off the back of it. I imagine they've had quite a few folks requesting a hi-def audio "SQ" based build. Prepare to shell some coin for one, but having seen them in action in Req's car, they're bad to the bone.
Oh, it's true all right. I have the ability, (it's quite easy really) to measure the sample rate and bit depth coming out of the Alpine H.U.Yeah, it would be quite strange if that were true. CDs are 44100Hz... CDs aren't the only thing that people listen to but one might think that rate would be supported...
DVD does not have one set sample rate. I know for a fact that it can be 48kHz, 96kHz or 192kHz, and am fairly sure that it can also be 44100Hz, 88200Hz (yes, it exists). Maybe even 32kHz, 16kHz, 8kHz, but hopefully nobody ever actually uses those ones.Even when I play a DVD disc in the alpine, the digital out is 44.1k, which I thought DVD was 48k.
Right, that's what I thought, so maybe the choice of DVD disc is a factor, BUT, why no 48k output when running 48k input from iPad via USB?DVD does not have one set sample rate. I know for a fact that it can be 48kHz, 96kHz or 192kHz, and am fairly sure that it can also be 44100Hz, 88200Hz (yes, it exists). Maybe even 32kHz, 16kHz, 8kHz, but hopefully nobody ever actually uses those ones.
Your HU may resample things to 44100 because maybe Alpine's DSP expects 44100... But I don't understand why they'd resample on the HU side rather than on the DSP side.Right, that's what I thought, so maybe the choice of DVD disc is a factor, BUT, why no 48k output when running 48k input from iPad via USB?
AWESOME sir, thank you very much! This is exactly the kind of info I was looking for.It looks like too save money they did not add a sample rate converter to the 360. So it can only accept its native sample rate of 48kHz. Using an external converter like and Audison SFC or a Mini DSP Minidigi should fix the problem.
miniDIGI | miniDSP
