1 - 11 of 11 Posts
Discussion Starter · #2 ·
Alright, I modeled this with linearteam after running across another thread. Looks like it will be -8db @ 30hz. I am not sure if this will be acceptable when you include cabin gain in the car. Or if it just looks awful.
After reading the reviews . . . NO to IB:(
quote>
not a cheap performer
Monday, October 6, 2008
Mike Burr from Kansas City Mo.
when I first bought the QT305,I was just looking for a low to moderate priced replacement for my 2.5 cu. ft. box. I installed the QT305,a 3in. id.x7.0 in. vent tube,and a 250 watt sub amp. The end results were way beyond my expectations. Even at moderate power levels the woofer gives a awsome performance.
quote>
yes to ported though :)
Thanks alot! That is what I had thought but wanted to make sure before I passed up a good candidate.
Evan
IB setup with a pair of 12" woofers in my 240sx ala Scott Buwalda's car. Essentially I am willing to give up no trunk space and am looking to pick up the low end that the 8" woofers in the door leave off. I can get Image Dynamics woofers at cost through a friend, so Ill likely do that.
Thanks!
OK ;)
mebbe one of these ? as a plan B ;)
XMax or efficiency might be desirable
quote>
With the growing number of infinite baffle subwoofer installs, Fi has decided to make 15" and 18" drivers designed specifically for IB use. Fi is requesting that all emails regarding the new IB subwoofers be sent to IB(at)FiCarAudio.com. The Fi IB subwoofers are available now.
Specs after the jump.
Fi IB 18" Subwoofer:
- 3" voice coil
- Triple stacked motor specific for the IB application
- Subs are linear limited at about 500-600 watts at 20Hz.
- $209 each shipped in the lower 48 States
- $199 each for orders of 4 or more
Re 1.5 Ohms (single 2 Ohm coil)
Le .87mH
Fs 22.9 hz
Qms 3.25
Qes .79
Qts .63
Vas 381 l
Mms 258 g
Sd 1210 cm^2
Spl 89.4 1W/1m
Xmax 30mm
Fi IB 15" Subwoofer:
- 2" voice coil
- Subs are linear limited at about 250W at 20Hz.
- $129 each shipped in the lower 48 States
- $119 each for orders of 4 or more
Re 1.6 Ohms (single 2 Ohm coil)
Fs 24.4 Hz
Le .72 mH
Qms 4.00
Qts .77
Qes .64
Vas 269.5 l
Mms 145.4 g
Sd 810 cm^2
Spl 90.0 1W/1m
Xmax is 22mm
quote>
OK ;)
quote>
- 3" voice coil
Le .87mH
Fs 22.9 hz
Qms 3.25
Qes .79
Qts .63
Vas 381 l
Mms 258 g
Sd 1210 cm^2
Spl 89.4 1W/1m
Xmax 30mm
- 2" voice coil
Fs 24.4 Hz
Le .72 mH
Qms 4.00
Qts .77
Qes .64
Vas 269.5 l
Mms 145.4 g
Sd 810 cm^2
Spl 90.0 1W/1m
Xmax is 22mm
quote>
I think they have a 12" version as well.
Also look at Acoustic Elegance's IB12
Stinky has 3 in his trunk, although Im not sure of hes gotten listening time in yet to give his opinions/review
Discussion Starter · #11 ·
Yeah, the FI and the AE's are awesome. The main reason I am looking at IDQ's is because I can get them at a very reasonable cost. There was a guy locally selling a pair of 12" kappa perfects which we were unable to come to an agreement on price with.
Evan
1 - 11 of 11 Posts
