hey doods sorry to resurrect an old thread, especially since the debucking need has largely been eliminated
... but alas, not
completely eliminated
Let's say someone is interested in the little 125mm (5 inch) driver, but has limited mounting room behind. Seems like the "hammer" method has been covered, as well as the "heat" method.
Let's discuss the "glue dissolving" method
Here's my thought : pour some kind of glue dissolver (acetone, paint thinner, ??) into a pan, maybe 1" deep. The depth is critical, because you want it reach the glue joint to be disolved ... but no higher. Then put the driver, cup and all, into the pan. I'm thinking that the dissolver won't be high enough to reach the top of the cup's outer perimeter, of course, but might just be able to seep into the joint through that hole in the bottom
Know what I mean?
What do you think? Any hope? If it works, it promises to be the most "gentle" technique, least likely to cause any unwanted harm. Any clue what type of dissolver would be best suited to the type of glue used?
