1 - 7 of 7 Posts
I've been looking through the old threads, and it looks like the problem with the DCX2496 is the ballanced XLR connections.
From what I can tell the options are
a) Isollate the Power supply. Since the ps is isolated, simple RCA-XLR conversion cables can be used.
b) Convert RCA-XLR using transformers (balance buddy). This will reduce/eliminate noise so isolating the ps is not necessary
I'm seeing threads about modifying the PS... I Don't know if I'm missing something, but it doesn't seem that complicated or expensive to me - pickup a inverter and a Isolation Transformer and there you go!
wouldn't something like this work?
Thanks,
-Jeff
DIYMA Founder
If you're using an isolating transformer, make sure it can handle a wide range of frequencies... Ideally beyond the audio range of 20-20khz, since you'd want a flat phase response as well. Also check to make sure it can handle the power you're going to throw at it without saturating. Efficiency may also be a concern.
Why would it need to handle the audio range?
It goes battery -> inverter -> Isolator -> DCX2496
I'm not talking about introducing any transormers into the signal path, just isolating the AC power. I'm no EE, but I think this would isolate the grounds so noise isn't an issue.
maybe not the most efficient way to do things, but would it work until Hans's mod is availible and I can afford it?
Also keep in mind that the ground pin has to pass on an isolator. Defeating the prupose of isolating the Behringer chassis from the vehicle chassis.
Chad
1 - 7 of 7 Posts
