1 - 9 of 9 Posts
· Registered
My buddy / mechanic has some sound deadener that he got from some online auto parts place, and he had offered it to me (for free). Sorry, I don't remember the brand. But its in 1 sq ft self adhesive squares, and aluminum backed.
Now although I'm pretty much a sound deadener dummy, I "Do at least know" that you don't want to use anything with asphalt in it. So the first thing I looked for on the package, was "ingrediants"...... but it didn't say (I guess they don't have to tell you what's in it, if it's not a food or drug). Well, keeping it a secret would mean to me > asphalt.
However, one of the uses it showed on the package was over the top of the motor / under the hood ? It seems to me, that if it were asphalt, it would possibly 1) melt on a hot day, over a hot motor, and 2) it would be flammable...... No ?
Anyway, its only like 9 sq ft.... so I definately need a bunch more, and the stuff I pay for will be butyl. But how do I find if this stuff my buddy has, is asphalt based ???
I'll try to get the name.... but I'm sure it's an off brand. As long as it's not asphalt, I don't think it could hurt anything, even if it didn't help quite as much as Damplifier or something expensive.
Your thoughts ?
Fish
PS, A completely different deadener question here..... But since somebody was calling me a post whore recently :) {wait.... they just said I sure posted a lot.... I called myself a 'post whore' :) LOL
Obviously one of the BIG reasons people deaden their vehicles is to reduce road / engine noise. And that's cool. I'd like that too. But how much difference does a well deadened vehicle make, when your sitting still, and with the motor turned off ? Just a little ? ....still a lot ?
Just curious.
· Registered
What was there before butyl based deadener? Dynamat still make a product for deadening the engine bay...
Just because it's asphalt based, doesn't mean it won't work... it just doesn't have the positive characteristics of butyl based products..
· Registered
Yep, Dynamat and Cascade both make products for under the hood. I think they're more fiberglass based, but I think it has a layer of deadener on it also.
· Registered
VMax
Does this make a difference? Yes, it reduces structure-borne vibration noise and refracts mid frequency noise to a different route, as in it makes your firewall, dash and vents seem louder. IMHO one cannot completely "kill" noise in a vehicle, only wound it really bad. It's like herpes; never goes away and shows up where you'd least expect it. :(
· Registered
So John, you would have been better of doing the engine side of the firewall(and the interior side), than placing the material on the hood, I guess...yes?
· Registered
My guess would be no as the firewall is convoluted and there's so many things attached to it - both would reduce it's RF and vibration potential. I could maybe see it worth it if you're doing like a kit car with a large flat firewall and you have easy access to it with the engine out, but I don't see hardly any value in vibration damping the engine bay side.
The real trick is getting multi-layer barrier(s) on the inside of the firewall as high as possible and as complete as possible.
Something like VMax is like .3 lbs/sqft. Mass blocks noise, as we all know. If your engine is blasting 100 dB worth of 250hz noise at a single layer of it...you might get a 1-2 dB reduction in the real world. On paper, you get 0.000 dB's.
· Registered
Right on, thanks.. ! I'm layered up as high as I can get without removing the dash and I might do that next winter..
· Registered
Just curious.
It still helps quite a bit when you consider panel buzzing, panel flexing, etc. It made a huge difference in my doors.
1 - 9 of 9 Posts
