1 - 20 of 34 Posts
· Registered
Hey if you want to sell it, NewTitan will buy em...JK
Got any more pics of the process you took when this happened?
· Registered
cam2Xrunner said:
This is what happened after he played music through them.
I am trying to imagine, the amount of excursion needed to cause that much damage (as pictured)...
So I would have to ask... how loud was the music playing? If I had to guess, it looks like the results of a really low freq sine at high volume levels...
· Registered
That's a shifted frame assembly, check out the surround.
Chad
· Registered
Discussion Starter · #14 ·
I'm not sure how loud he was playing them.
I wouldn't buy these though unless I knew for sure that I wouldn't mess them up. Say you mess up only one of them, that would bring the cost close to 50 bucks per driver if you had to buy another one. This guy messed up two of them, then decided to buys Seas drivers. :rolleyes:
That's 4 people I know of now that has ruined these things. Why can't they just make a non-shielded version?
· Registered
If you don't feel comfortable taking the chance, nothing the few of us that have debucked them with eaze can say will help you.
The bottom line is if you can't spare the $50 to take a chance... don't do it. :rolleyes:
The non-shielded 4ohm designs are rumored to be released, but not before the RS line of subs (from what I have read in forums).
Until they are out... either wait or get the Seas. After all although I have not had the pleasure to listen to the Seas, I hear they are just as good if not better alternative to the RS...
· Registered
Hmm...that's crazy that people have been having troubles with the daytons. I wrote the guide thingy on ECA and the only problem i had was getting the black shield off (DO NOT ATTEMPT TO CUT IT WITH GRINDER :D hehe).
But other than that, just make sure you have the right tools (hammer and some sort of chissle or big screwdriver), and it's relatively straight forward...
Now if i could just find the magnets to use the daytons in my home theater project...
Otherwise i've got a couple debucked Daytons for sale :)
Later guys
Mark
· Registered
I just debucked a pair of RS125's that wil go in my Saturn. I must say I feel it is getting easier to do...
I don't use a hammer either... I use a plastic hammer\mallet.
· Registered
add one to the casualty list... my cone is frozen. I did have to whack it lot to bust the stupid shield loose. I don't know how you guys are tapping it a couple times and it coming right off, that thing was ON there.
· Registered
trust me when I say heating the sheild on a stove is WAY easier!
just put the driver on a pan (i used one of those coated non stick pans prolly teflon or whatever)
wrap the drivers basket in foil then the trick is alternating heat. put the stove on the highest setting for 30 seconds then turn it down and repeat for 10 minutes then put the drivers sheild in a vice and pull.
comes off so easy you would NEVER think of hammering the sheild off again. easy as pie.
and as I mentioned in the diy articles, I thank whoever came up with this idea because I would have frozen my drivers for sure.
· Registered
I tried the mallet but had to go back to hammer,heres mine on the left............
1 - 20 of 34 Posts
