261 - 280 of 1122 Posts
Thanks. I did exactly what you said. But used Switch Sound file converter to convert the Flac files into 16bit/44.1 wav files.
I still noticed a difference. Not as much as the 320kpbs songs vs CD.
Some people say its a placebo but I definitely heard a difference in CD vs. Wav.
I would say at most a 5% difference but it was still there.
There shouldn't be differences between flac and wav as both are lossless. You might want to check if both sources were played back with the same decibel level. USB is a different source from CD and the dB levels should be exactly the same to compare both. In most head units different sources can have different level settings. I know I can adjust each input on my HU.
But as a musical source signal it shouldn't differ. As long as both files are in the same format, for example 16 bit 44.1 khz.
Most precieved differences come from playing 2 tracks at a different dB level.
The loudest usually gets the vote.
If you take a 16 bit 44.1 khz flac, convert it to wav 16 bit 44.1 khz and back to flac 16 bit 44.1 khz the file should be exactly the same.
Lossless is lossless independent on format ;)
Lots of mp3 bashing here. I will post some data tomorrow on mp3 vs lossless and show you what the differences are by measurements!
Many downloaded mp3s are encoded with bad settings/codecs. Joint stereo is one of the things...
When I used Foobar to convert 24/96 FLAC to 16/44.1 WAV, yes there was a difference when heard on good-quality headphones and on my home audio system. A little narrower stage width. Slightly shallower stage depth. Some loss of low-level details. But I don't have that many 24/96 FLACs to begin with.
When I used EXACT AUDIO COPY in "Secure Mode" to rip an original audio CD to WAV, there was no audible difference both on headphones and on my home audio system. EAC is the defacto standard for converting "Red Book" CD audio to WAV.
So these WAV files are what makes it on to the USB hard drive that I use with my P99RS.
On another note, my friends and I have tested several USB 3.0 hard drives with the P99. Seagate, Western Digital and Samsung. All three will work as long as it is plugged directly into the USB lead of the P99 - not using the USB extension cable that comes with the P99. When this cable is used, the P99 was unable to read the USB 3.0 hard drive.
But USB 2.0 works every time. :)
Well I converted directly to WAV format from the CD. The quality was a bit better than before but still not like CD quality. Better than when I recorded them into FLAC and then converted from that.
In EAC the wav tab....there are two options high and low quality cant seem to click the high quality one ...dont know what the issue is.......
thanks for the 2.0 hard drive heads up.......
think I might try foobar and see if I can get exact cd quality
Hmm..is this still a p99rs review/discovery thread?
I have been using a p99 for the last 6 months and indeed have many queries on it which I will post later......just was trying to get some guidance from people who have converted their music to something portable without sacrificing any quality. With the 99 want to hear every note in my music to the fullest.
Is anyone else peeved that the display doesn't change colors like the trim of the knobs do? Why the hell wouldn't Pioneer make that an option?
Wav will not sacrifice any quality as long as the ripping tool or transcoding software doesn't mess it up.
Take your favorite CD, rip it with something like the EAC (Exact Audio Copy) ripping tool to wav. Burn the wav files to a CD-r and compare both CD's. That should give you your answer. Oh yeah, make sure someone other than you loads the CD's for that test so you don't know what CD is actually playing. That alone can make a very big difference!
Discussion Starter #270
not an issue for me. i think pioneer wanted to go the way of clean minimalism with the styling- emphasizing the sound quality rather than the glitz.
occasionally i see those double din touch screen units and think they do look pretty cool - and then i see my nice clean understated P99 in my dash and hear the clean amazing sound of the music and i realize there is no contest.
if i had to request some changes for the next version of the P99 here are some for starters-
*9 channels- sum the extra one for subwoofer duty. would really love a 3-way active front stage and rear full fill.
*double din with a larger, non touch screen display.
*integrated RTA with generator and programmable frequency curves
*bluetooth integration for enhanced remote tuning control via laptop, tablet or phone.
*state of the art DSP software ap with multiple dialog boxes and controls open for every network- one-page tuning- minimize the amount of menu steps / buried menus required for tuning
*integrated HD radio.
*front panel usb and aux access
I was with you until you said front panel USB/aux input. I think that is the tackiest, cheap-ass thing ever on a HU. Nothing says high end HU like an add-on cable jutting out of the front of it.
I like everything else though.
Discussion Starter #272
good point- do the work and route the cable from the back, i agree.
but a nice clean SD card slot in the front I could live with.
i didn't think about this but i would like to keep the motorized display door even if it were a double din, half of it could open.
the card slot would be behind the display / door.
Exactly what I was thinking. VW actual integrated the SD card slot very well on their OEM HU. Pioneer does as well.
Like you, of prefer it behind the face like Kenwood does. Alpine too, I think.
props on the DSP software and bluetooth. BT would have been real handy for such a high end unit
Well I ripped the CD and played it back ......took a blind test.......had a friend do it......results I noticed a big difference.....the original cd still sounded way better......
the software used was Exact Audio Copy.....Dunno I think I may just stick to using original cds have tried everything else
The things I'd ask for is first and foremost presets. Wish to God I could slap together one tune with X-overs, TA and EQ and compare it with one that's different. So much easier when you can just switch between them.
Why oh why is half the display blank? Drives me insane that the clock and track number are so small that I can barely see them. Why are they so tiny and stuck in the top of the screen with the bottom 2/3 of the screen mostly blank.
Better remote or at least better UI. Make it not so maddening to work in the audio settings. You have to use the remote because you can't see any other buttons and the knobs are so short that you can't turn them unless you have fingers the size of a 10 year old's.
Other than that I absolutely love this near work of art Pioneer has put together.
Sent from my HTC Thunderbolt using Tapatalk 2
Did you burn a CD from those wav files? If not, then there are other reasons possible for your findings. Have a friend swap CD's on you a few times without telling you what you are listening to.
Lossless is lossless. If there were a difference then your computer got issues xD
Sent from my Samsung Galaxy 3 via Tapatalk.
Well maybe Pioneer will make something like this for the car:
They have the technologie (lol)
