Subd ,great advice here's guys!this is why I love this site so much
I believe you can just set the slope to flat and it will output full bandwidth.Question for you P99 experts:
Can you run a full bandwidth signal out of each channel (high, med., low)? Or do you have to work with the x-over parameters listed in the manual?
I'm mostly curious about running a quasi-active set up out of the high channel. It would be a HAT L4 bi-amped with their L1 using HAT x-overs. Is it possible to run a full signal out of the high channel out of the P99 and set a high pass of around 400Hz at the amp?
I'd want to keep the mid, low, and sw channels for something else.Just going over some system designs in my mind. I've checked out the manuals for the P99 and it is not clear to me if you can run full bandwidth signals out of the high channel.
Thanks!
IIRC, the high ch has a fixed highpass applied. I believe 1kHz/6dB was the lowest you can go...Question for you P99 experts:
Thanks!
Bummer! Can anyone else verify this? The manual says 800Hz is the lowest HPF you can apply. However, there is the PASS option for slope. Does choosing the PASS option for slope send out a full range signal out the high RCA's?IIRC, the high ch has a fixed highpass applied. I believe 1kHz/6dB was the lowest you can go...
Unfortunately not on the high channel- most likely built-in tweeter protection so consumers are not pissed off because of blown tweeters during the autotune function.Question for you P99 experts:
Thanks!
Bummer! Thanks for the info avanti. This is exactly what I was curious about.Unfortunately not on the high channel- most likely built-in tweeter protection so consumers are not pissed off because of blown tweeters during the autotune function.
You are limited to 800Hz, 6 db / octave High Pass on the high channel. All others can be full pass.
I have my midrange with passive low pass / high pass to tweeter on the high channel.
Some very credible mobile audio experts believe that an 800Hz crossover between midbass and midrange works well with the typical lower door / upper door or a-pillar configuration. Hopefully they are right because with the P99 running rear fill 800 Hz is it.
I had my P99 running F/R/S and it is definitely no optimum. Mine has been sitting in it's box for over a year since removing it from my previous vehicle as I'm still looking for just the right amp & two way front stage speakers for my '12 Accord sedan. Also considering a band-pass vented through the sub grill so my trunk lid doesn't rattle. Spare $$ is limiting factor for now. IMO, if you want to run F/R/S, get a different, less expensive HU.I'm about to install a p99, I can't decide if I want to do 2-way plus sub and rears, or just two way with sub.
Either way, I can use the 1st of outputs for highs correct?
Okay thanks for the input. however having such a sensitive hear i am 100% sure that the same song played from my phone through bluetooth and even usb is different quality than when i plugged in the ipod......iPod/USB/CD sources are all identical. AUX-in however is not.
Can't remember, but ain't some of the "sound improvement" settings stored into different sources? So it remembers the settings for USB and one for CD etc etc. Could be wrong, otherwise it's probably the brain playing tricks on you. Everything is processed through the same DACs.
