Kenwood DDX-7015 6.5" Screen $360 shipped w/ paypal
I've had this for a few years and it works like a champ. No scratches on the screen. Comes with remote. Plays everything - mp3 discs (both cdr and dvdr), cds, dvds, burned dvds, 18 fm presets, 6 am presets, etc etc. This screen works perfectly.
Focal Utopia 5WS 5" Subwoofers (Pair) $240shipped w/ paypal
I have no room for them in my kick panels, so they have to go. Near mint - only some surface scratches on the magnets which arent very noticeable.
Special long excursion subwoofer.
136mm subwoofer for small bass reflex enclosure.
40mm voice coil, 100mm magnet
Impedance: 4 Ohms
Max. power handling: 160W
Nominal, power handling: 80W
Sensitivity (2.8 V/1m): 87dB
Frequency response: 45Hz*-2.5kHz *Depends on load
Mounting Depth 74mm
Diamond Audio D7401 Reference Amplifier $375 shipped w/ paypal
This is top of the line Diamond Audio! Not only that, but the D7 series is considered to be one of the finest series of reference quality amps. Absolutely Brand New! Its seen power for testing purposes, but has never been used in a car or mounted to anything. Amp comes with birth sheet, original box, manual, and original packaging. The side panels are detached in the picture because i was cleaning some dust out since the amp had been sitting for a while. It will have all the panels attached and will work and look as new! The reference # is a d7152 number because they are the exact same amp, except the d7401 is wired for mono internally.
400 Watts x 1 @ 4 Ohms (Birth Sheet shows 425wrms @ 4ohm)
800 Watts x 1 @ 2 Ohms
Frequency Response: 3-50,000 Hz
Signal-to-Noise Ratio: 102dB
THD: 0.02%
Length: 19 1/2"
Width: 10 5/8"
Height: 3"
Morel Ultimo 10 (only sub, no box) $350 shipped w/ paypal
Great working condition. Bottom of the motor has some surface scratches, but they arent any big deal. Its louder and clearer than a W7. You can't be disappointed. The Ultimo series won "Best Subwoofer of the Year 2008"
Overall dimensions DxH 263mm (10.53) X 140.3mm (5.52)
Power handling RMS 1000 W
Transient power (MAX power) 3000 W
Sensitivity 2.83 Vrms / 1M 87.5 dB
Sensitivity 1W / 1M 84.5 dB
Frequency response 10-900 Hz
Cone material Carbon-fiber laminated paper
Net weight 6.5 Kg. (14.3 lb.)
Driver Displacement 2.34 Lit (0.08 cu.ft)
Voice Coil Diameter 130 mm (5.1)
Voice coil height 37mm (1.45)
Voice coil former Aluminum
Voice coil wire Hexatech Aluminum
Number of layers 2
Max. Linear excursion X 12.5mm (0.5) (Each way)
Soundstream Picasso PCX2000D $280 shipped w/ paypal
Like new. Only used for 6 or so months. Comes with original box and paper work, end caps, remote bass knob, etc.
Number Of Channels: 1
Low Frequency response: 10 Hz
High Frequency Response: 35000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
RMS Power @ 4 ohm: 1100W x 1
RMS Power @ 2 ohm: 1500W x 1
RMS Power @ 1 ohm Mono: 2000W x 1
MAX Power @ 1 ohm Mono: 4000w x 1
TSTTM (Twin Stack Technology) Allows 2 amplifiers to power single load
FR4 Circuit Board
Mono-block Mosfet Class D Circuitry
Continuously Variable Low-Pass Crossover
Continuously Variable Subsonic Filter
Variable 18dB Bass Boost
Platinum RCA and Power Inputs
1 Ohm Stability
Accepts up to 16V DC Power Input
Glossy Black Hairline Anodized Heatsink
End Caps for Professional Installation
THD: 0.50%
S/N ratio: >85
Damping Factor: >200
Input Sensitivity: 200mV-8V
Subsonic Slope: 24dB
Subsonic (Hz): 15 - 40
Low Pass Filter(Hz): 50 - 150
Low Pass Filter slope: 24dB
Subwoofer EQ.: 0-18dB
Phase (degree): 0 - 180
Remote Bass Boost Control included
Dimensions:10"(W)x2.5"(H)x22.2"(L)
Impedance: 4 Ohms
Mounting Depth 74mm
THD: 0.02%
Length: 19 1/2"
Width: 10 5/8"
Height: 3"
Number of layers 2
FR4 Circuit Board
1 Ohm Stability
THD: 0.50%
S/N ratio: >85
