1 - 11 of 11 Posts
DIGITAL DESIGNS SS4- 4 CHANNEL AMPLIFIER
This amplifier was purchased brand new and comes with everything. Condition wise this amplifier is a 9.8/10 if not better.
Features
Compact Size for Installation Versatility
Clipping indicator LED on the chassis for ease of tuning
High-End 18dB/Oct High-pass & Low-pass Crossovers
105dB Signal-to-Noise Ratio
Damping Factor Greater Than 700
Crossovers are defeatable for High-pass, Low-pass, Notch, Band-pass and Full-pass operation configurations
SPECIFICATIONS
Series SS
Input Sensitivity 0.2V - 8V
Variable High Pass Filter 20Hz - 5kHz @ 18dB/Oct
Variable Low Pass Filter 50Hz - 5kHz @ 18dB/Oct
Clipping Display LED
Tested Voltage 14.4
Tested THD 1%
Model SS4
Cont Power at 4 ohm 50W x 4ch, 180W x 2ch
Cont Power at 2 ohm 90W x 2ch
Damping Factor >700 @ 4 ohms
Dynamic Power 400W
Efficiency thru Output >66%
Dimensions - mm 250L x 175W x 52.5H
Dimensions - inches 9.84L x 6.89W x 2.07H
Signal to Noise >100dB
Shipping Weight 10 lbs.
$255 SHIPPED FIRM, NO TRADES
I am thinking about this...I like the size. never ran a DD
If this helps jax... the s4a I had ran a system nicely... I ran passives up front and bridged the rear channels to a sub. I also ran it active. It did a nice job. Nothing over the top but it did sound good and I never had a hiccup the year that I had it.
1 - 11 of 11 Posts
