Hey, I'm building my box (3x 10s with 2 amps all in one) and the amps are located at the very end of the car, with the subs inbetween the the amps and the rest of the car. To make it a clean install, I want to run the cables through the sub airspace to the amps. But in the off chance I need to take the whole thing out, the cables would all be siliconed to the box and wouldn't be able to take it out.
I want to make them so I can disconnect the cables (does not need to be with ease) from the back of the box and take the box out. I am going to use a female-female for the rcas and now I'm stuck on the power wire. I read a good bit around here and keep seeing these:
Parts Express:4 AWG Breakaway Power Connector 175A
Which work for me, except I only need to use one side of it, and kinda expensive. Are there any other solutions I can do? Perhaps a conductive bolt through the back of the box and connect both sides of the wire (don't like that, too much metal exposed)? Any ideas, or should I use the parts express and just leave one open?
Thanks alot
Thanks alot
