1 - 11 of 11 Posts
· Registered
Okay, I bought a pair of these.......
(NHT XdS bookshelves w/Seas 5.5 & 1")
and a pair of these.......
(2X55-Watt @ 4-ohm 24dB 2-way @ 3.2 kHz, Selectable 12dB Hi-pass (subsonic filter) @ 30 or 60Hz)
one of these........
(200-Watt @ 4-ohm Lo-pass @ 40-140Hz)
Now I need a sub. I already have a single tang band long-throw neo 6.5. Maybe I could use a couple(few) more. Hmmmmm.........
Any suggestions?
· Registered
How large of a room are you looking to fill with bass?
Bear in mind that a 6.5" sub will not adequately fill anything more than *maybe* a 10x10 room, and it won't get very low either.
Since you already have one though, I'd suggest buying 3 more, since they're only $50 and handle 50RMS, and wiring them in series/parallel to present a 4ohm load to the amp.
· Registered
This will be in my bedroom which is about 15' x 15'. But, with that said, I'm not necessarily looking to fill the room w/bass. I just want an reasonable amount to compliment the bookshelves in the lower octaves. I've built a couple of home subs in the past with the 250W Parts Express plate amps and single car audio (JL, RF) 10's and 12's. For this project, I don't think I need near that much output.
Keep suggestions coming. I'm currently thinking one more TB neo 6.5 (2 total) in a ported box???
· Registered
Tapped Horns
I would say try two of these.
If you build it for me. Holy shmokes! Little outta my league, but I bet they sound nice.
I got the bi-amps up and running on the XdS bookshelves. Me likey! I am an active fanatic and these things sound damn good! I can't freaking believe the bass response that the Seas W15CY is capable of. If I could get 5.5's to sound like that in my truck I would sell tickets to come listen.
· Registered
Discussion Starter · #8 · (Edited)
The single fold 38hz design is much simpler. The reason for suggesting the tapped horn was that will improve the 1w/1m efficiency, which would compensate for the lower power handling of the little tb 6.5s.
http://www.volvotreter.de/downloads/TangBand_W6-1139SC_38Hz_TH_Rev_0.pdf
Here is another project:
Parts Express DIY Project
That one appears simpler, I think I'll give the "double-folded" version a shot. I've seen that parts express "boogieman" before. I'm really gonna strive to use only 2(or less) drivers.
Though I didn't mention it earlier, I also played a bit with the single TB 6.5 this weekend. It reaches xmax pretty early. Definitely before I'm satisfied, so I'm going to experiment with enclosure first, then adding a second driver. The tapped-horn may be my ticket to small sub bliss....
· Registered
Discussion Starter · #9 ·
Well, I saw the DIYMA 12" clearance that npdang is gracious enough to offer. I ordered one and plan on putting that in a sealed box. The tapped horn w/the tang band will have to wait.
I plan on mounting ALL 3 plate amps in the sub enclosure. I will take pics when construction begins.
1 - 11 of 11 Posts
