1 - 18 of 18 Posts
Just clearing out some of my car audio equipment.
DLS CCI-500 SOLD
Output power in 1 ohm – 550 Watt
Output power in 2 ohm – 370 Watt
Output power in 4 ohm – 200 Watt
Subsonic filter 30 Hz, ON/OFF
Filter low pass 35 – 250 Hz, 12 or 24 dB slope
Grand bass filter Bass boost 0- +6dB variable
Phase control for subwoofers 0 or 180 degrees switch
High level input with auto start Yes
Dimension (W x D x H) 129 x 304 x 51 mm / 5,07 x 11,96 x 2″
DLS CC-1000 $285 + Shipping
Output power in 1 ohm: 1000 W RMS
Output power in 2 ohm: 700 W RMS
Output power in 4 ohm: 440 W RMS
Frequency range: 10 Hz - 500 Hz
High pass filter: Subsonic 30 Hz, ON/OFF
Low pass filter: 35 - 250 Hz, 12 or 24 dB slope
Grand bass filter: Bass boost 0- +6dB variable
Phase control for subwoofers: 0 or 180 degrees switch
Rec. power cable: 2 AWG / 33 mm2
Fuses: Use external fuse 100 Amp
Includes Bass Knob
Dimensions (W x D x H): 129mm x 368mm x 51mm (5.07" x 14.48" x 2")
273204
273205
273206
273207
Does the 1000 come with a bass knob (not sure if it’s called that?
1 - 18 of 18 Posts
