1 - 19 of 19 Posts
Another one out of storage, never been used, open box.
Specs:
SOLD
Amplifier class – AB
Power output, 4 ohm bridged – 2 x 200 W
Output power in 2 ohm – 4 x 100 W
Output power in 4 ohm – 4 x 70 Watt
Damping factor >80
S/N ratio, A-weighted >95 dB
Frequency range 10 Hz – 30 kHz
Input sensitivity 0,25 – 5V
Input impedance 22 kohm
Input impedance, high level 47 ohm
Filter high pass 50 – 500Hz / Can be Switched in/out
Filter low pass 50 – 500Hz / Can be Switched in/out
Bass EQ @ 50 Hz – +6 dB
Power consumption (idle) 0,5 A
Power consumption (max) 50 A
High level input with auto start Yes
Integrated fan
Fuse – 2 x 25 A
Dimension (W x D x H) 189 x 322 x 46 mm (7,44″ x 12,67″ x 1,81″)
273643
273644
273645
273646
Do
You know how well it does with midrange or horn tweeters?
Haven't used one with horn tweeters however when I installed one in a customers vehicle using components I noticed the sound is on the warmer side, mid-range was still detailed but not emphasized, midbass output was better than other amplifiers in the same price range.
1 - 19 of 19 Posts
