1 - 20 of 49 Posts
I am getting rid of a ton of stuff. All prices posted are negociable - paypal fees to be covered by purchaser. 3.3% on top of prices. Any questions please let me know
I have 3 prestine DLS Ultimate amps for sale. All are genuine authentic.
I will have pictures up later this afternoon. I know times are tough and i'm feeling it directly. Looking for 275 shipped for the a2, 350 shipped for the a3 and 400 shipped for the a6 or ALL 3 FOR 900 SHIPPED!!!!!
All amps are less than 6 months old.
once again pictures will be up this afternoon. I have no need as i got a new car and i don't really want to mess with the system on this one.
Specs:
A2
MobileSQ.com
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz , < 0,1% distortion.
Mode : AB
Number of channels : 2
Nominal power in 4 ohm : 2 x 50 W
Typical power in 4 ohm : 2 x 85 W
Typical power in 2 ohm : 2 x 145 W
Typical power in 1 ohm : 2 x 220 W
Typical power in 4 ohm bridge mode : 290 W
Typical power in 2 ohm bridge mode : 450 W
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,2 - 7 V
Filter, highpass, variable : 20 - 200 Hz
Filter lowpass, variable : 50-125 Hz
Terminal for external cooling fan : No
Current draw, idle : 0,6 A
Current draw, maximum : 60 A
Dimensions W x D x H : 265 x 240 x 73 mm (10,43 x 9,45 x 2,87 inch)
Weight
: 3,7 kg ( 8,16 lb)
A3
MobileSQ.com
Mode : AB
Nominal power in 4 ohm : 2 x 100 Watt
Typical power in 4 ohm : 2 x 150 watt
Typical power in 2 ohm : 2 x 270 Watt
Typical power in 1 ohm : 2 x 425 Watt
Typical power in 4 ohm bridge mode : 550 Watt
Typical power in 2 ohm bridge mode : 870 Watt
Typical power in 1 ohm bridge mode : 1200 watt
Terminal for external cooling fan : Yes
Double DC-inputs : Yes
Phase shift button : Yes
Current draw, idle : 1,1 A
Current draw, maximum : 140 A
Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight
: 6,2 kg ( 13,67 lb)
A6
MobileSQ.com
RMS output per channel at 13,8 volts, < 0,1% distortion.
Mode : AB
Number of channels : 1 ( for subwoofer use )
Nominal power in 4 ohm : 500 W
Nominal power in 2 ohm : 870 W
Nominal power in 1 ohm : 1200 W
Filters : Lowpass: 50-125 Hz. Subsonic: 25 Hz
Dual DC-inputs : Yes
Phase control 0-180 degrees : Yes
Remote sub level control with phase shift : Yes
Weight
I am also selling a H701 / C701 Combo. I'm looking for 350 shipped for both. I can't find the controller cord but they can be found on ebay for cheap!!! SOLD
I'm selling a barely used w505. I am looking for 600 shipped for this. I LOVE IT but my new car is single din. Can't find the box or manual but i will include a wired TR7
I found a DVA-7996 looking for 250 shipped NO BOX
Also have a pair of seas lotus RT25f tweeters 125 shipped NO BOX
ONCE AGAIN PICS UP THIS AFTERNOON
If the H701 is in perfect working condition, I'll take it. You want $350 for the H701 AND C701? Please PM me with your paypal info.
I don't really need the controller if someone else wants to buy it. If you are not seperating though, for that price I'll take the combo.
i want to think that all prices are good. i just hope there is enough interest right now with the economy. I am open to all offers though, i don't use it anymore so i need it out of here.
Any imperfection to the screen on the 505? Anything else missing?
Discussion Starter #13
no imperfections in the 505 screen at all. just don't have the box and the manual. I have all the usb stuff and ipod stuff
1 - 20 of 49 Posts
