I am curious to know logically heat is what makes efficiency go down lowers sq and also kills rms as long degrades electronics etc. if it did I’d use some high end paste but even if this isn’t possible I’m considering on getting custom noctua ippc 3000rpm ip67 fans in there since heat goes out thru the heat sinks having the air blow inside more and fans on the outside would keep the amps cooler and more efficient. I’m still planning out a lot of my build here and running class ab amps are hot. Just thinking on options that would be cool to keep the electronics coolers
