1 - 19 of 19 Posts
Newb, 1st post. When you mount new after-market speakers to an adapter or factory mount, do you use Silicon to seal it? I know you are supposed to use it between the adapter/spacer and the door. But between the speaker and adapter, I wasn't sure. Thanks in advance.
No, nore will I ever!!
I prefer non-hardening modeling clay, can be purchased at hobby shops.
Look in the build logs and you'll see how it's been used by some folks !
The fumes/chemical off gases from silicon can and do adversely affect many Different materials. I second, non hardening modeling clay. I've even seen it at the local dollar store though I haven't tried it yet.
"duct seal" (found in the electrical section of your local home improvement store) or clay also makes for a decent deadener around baffles. Not sure if MDF will suck moisture out of the clay and become swollen and soft. Anybody?
Personally I use Stinger Overkill as a gasket material, easily compresses to make an airtight seal, no residue on the speaker if you remove it, cuts quickly to size with a razor knife or sissors and is fairly inexpensive.
I second the rope caulk. Very easy to size, place, handle, and remove. Also, it's completely weather proof so it won't degrade.
Yes. I let it dry for a few days so it gasses off.
I normally keep a cheap roll of the gray self adhesive weatherstripping you can find just about anywhere including wallyworld. I use it for speaker mounting gaskets especially subs. Stopped using silicone years ago due to cure time, mess, and potential damage from fumes. Weatherstripping is just plain simpler.
Unsealed MDF will absorb oil from the clay. It swells with water, even high humidity will do it over time.
Another yes vote for rope caulk.
Available in the weatherstrip aisle of the hardware store.
Banned
Just use CA glue then liquid nail , then roofing tar. :D
But rope caulk works good also butyl rope
Will have to check out that rope caulk at my local Ace hardware.
I hate rope caulk, putty, closed cell foam, silicone etc.. This stuff is great, has a peel and stick side and is very flexible to make a flat turn around cutout and compresses perfectly flat.
Good thread! I'll have to do this soon, probably should have done this when I deadened the door...
Damn.. beat me too it..
I use this stuff ALL the time, got it awhile back, has lasted me through a few installs..
Speaker Caulk...
12" Speaker Sealing Caulk Box of 72 Pcs. 260-400
Seals like CA & liquid nails, looks like roofing tar, but comes off a lot easier.. ;)
AND if you need something thicker (speaker ring mounts to doors, between tight spaces, etc)
Use the rope from Don at SDS.. GOOD stuff..
1 - 19 of 19 Posts
