If you have a three way setup that is done actively, with a deck that has attenuation, cross-over and timing controls, is it okay to place the tweeters basically anywhere with the woofer being in it's normal lower door/kick pod position?
I ask this because I've read that you should keep the main tweeter as close to the primary mid-range woofer as possible. But, isn't that just because you don't want to screw up timings and volumes. If you have electronic control over that is the tweeter level a non-issue?
I see a lot of people on here with main tweeters mounted in the sail panel/lower a-pillar area.
