I've been installing my minidsp in my car and it works great when hooked up to my computer but doesn't do anything when plugged into my car's USB. Does it need a computer to work or is it just my car's usb doesn't give it power because it doesn't recognize it?
the minidsp is only programmed with a computer. once you disconnect it, i twill work on its own. why are you powering it with a usb connection? the green connector has B+, remote and ground on it. you need to connect those to your car.
I am assuming you did buy and install the plugin for the minidsp?
It's just temporary. I'm wiring it to 12v today, I was just wondering if something was wrong with it. Everything's set up already except for it being wired in.
couldn't tell ya. maybe when it detects usb power it is expecting a computer connection, so none of the functions are working. get it wired correctly and see if it works.
