Would you be able to hear the port noise while sitting in the car?
Not as much, but there is still compression to consider, you can get away with much higher port velocity in a trunk until compression becomes a problem.Would you be able to hear the port noise while sitting in the car?
30 m/s shouldn't be too bad in a trunk.I have been modeling Dayton subs and to keep port lengths reasonable I am in the 30-40 m/s range for most of my models with a best case scenario at 27 m/s
They are pretty effective at reducing noise.And while I am at it, how affective are port flares?
That makes sense. I am not running enough wattage to lose any db so I better keep it under 30 m/sFor what it's worth, I ran a single 15 with a 4 inch square port 1 foot long (tuned at 26 hz, 35 m/s port velocity, no flares) in a hatchback and I never noticed the noise until it got down into the low 30's. That was a 150 db setup with 1200 watts on up to 2200 watts, port compression kept it from going louder with the extra power.
These are considered generalizations:Good to know. I keep reading online that people aim for 17m/s or less, nice to hear some real world examples.
Very good point and the answer, in my case, could very well be almost never after tuning and equalization.But that brings in another caveat, how often are you planning to run at max spl?
So between being in the trunk (less noticeable from noise perspective) and not running at peak excursion and assuming your using a circular port then you should be good up to a calculated max of 45-50 m/s.Very good point and the answer, in my case, could very well be almost never after tuning and equalization.
17 m/s is the target for zero to minimal port noise without flares, but some of us would need an 8 inch round port 6 feet long to hit that goal. Compromise is key to making car audio work.Good to know. I keep reading online that people aim for 17m/s or less, nice to hear some real world examples.
For sure17 m/s is the target for zero to minimal port noise without flares, but some of us would need an 8 inch round port 6 feet long to hit that goal. Compromise is key to making car audio work.
If you ever want to put an SQL15 in your trunk I figured out a way to put a 10' long port (it's actually 9' 11") on a 3 cube box... 18.5Hz Baby17 m/s is the target for zero to minimal port noise without flares, but some of us would need an 8 inch round port 6 feet long to hit that goal. Compromise is key to making car audio work.
Sweet! But 88 Camaros can't fit large box-shaped boxes, my last ported 15 took up the entire hatch tail lights to back seat below the window level. No more of that crap for me, I'll just run sealed.If you ever want to put an SQL15 in your trunk I figured out a way to put a 10' long port (it's actually 9' 11") on a 3 cube box... 18.5Hz Baby
