1 - 6 of 6 Posts
was hoping i could get some guidance on this. honestly, i'm not so sure why it's bugging me so much but i keep second guessing myself. i only included power and signal turn-on, signal flow i have down. the remote/switched lead going to the relay and then to the blue sea block is what's throwing me. let me know if this looks ok or if not, please correct me.
oh, and im using the high level output of the factory uconnect to feed the rf360.3 if that helps.
So the DSP is turned on when it senses a signal from uconnect, and then the DSP is supposed to turn on the amps?
What is the square w/ a cross in it supposed to be? And what is the box w/ NEG, POS, and FUSED supposed to be?
so yes, the dsp should use the high level signal sense to then send a remote turn-on out. i believe the 360.3 can turn on up to 3 amps, but i'm also looking to turn on things like fans (box with the 'x') and maybe some led's. so that's why i am thinking the remote out from the dsp to a relay which then goes to the blue seas systems distro block (other red/black box). this, then, could turn on all the amps, fans and lights.
Well then it looks good to me. I did note that u have 2 power and 2 ground wires running to Amp 2, but I'm guessing that's just a mistake in the diagram.
1 - 6 of 6 Posts
