21 - 40 of 43 Posts
I want to add a "I don't trust you with my stereo switch" as well as a switch to turn it on without the key present.
When I did mine, I had a couple issues to overcome. 1st, Mazda made the audio system very modular. You can add BT and Nav and Satellite to it in sections. Problem being, mine came with BT, and after I installed the new radio, the old BT module kept trying to pair to my phone. I eventually had to unplug it (above the glove box) because it wouldn't pair to the new radio while it was trying to pair to the old BT module.
When I had the illumination wire hooked up, I got noise through bluetooth (streaming) on my new radio when the car was running. I disconnected it for now, but when I go back in, I'm going to use a relay to see if the noise goes away.
Finally, when I did my steering wheel controls (I used a Maestro SW, but a Pac SWI-CP2 would be a good choice as well) I had to grab one of the wires at the steering wheel so my BT buttons would work. It goes from the steering wheel, through the BT module and since I disconnected the BT module, it couldn't see those buttons, or they are completely isolated from the radio. You can most likely get them at the BT module, but steering wheel was easy to get to.
Also, I picked up a new daily, and I'm considering moving up to 15" IB subs, or 12" enclosed subs, and might move my Acoustic Elegance 12's to the new daily. I haven't decided yet. It's a smaller car, so I don't know how much space I want to give up.
The IB wall wasn't super complicated. I made mine from 3 layers of 3/4" MDF, and recessed the subs 3/4". I mounted it with metal brackets I picked up at Home depot. I left about a 1/16-1/8" gap around it, and filled the gap with black silicone to (hopefully) avoid squeaking. So far so good.
Sorry you didn't get a listen at Finals considering how similar the cars are/will be.
Jay
Discussion Starter #22
Jay
I havent had issues with the bluetooth module or the ilumination noise.
As far as the steering wheel controls, the workshop manual mentions that the bose and non bose wiring is different. The Bose unit does have the phone buttons on the harness and the non bose doesnt.
261245
261246
J.
Reactions: bbfoto
Discussion Starter #23
Got the power wire in.
The OEM battery has a fused terminal which has and empty spot with a 60 A fuse that just so happens to be what the Zapco ADSP-Z8 needs.
261247
So I got a ring terminal and crimped the wire, got a 10 mm nut to hold it in place and used wire loom to make it look oem.
261248
Used the OEM positive terminal cover and it looks like nothing happened.
In case I blow the fuse, the entire fused terminal is $23 dollars and I ordered a new one just in case.
261249
Ran the wire into the cabin via the OEM plastic boot.
261250
Zip tied it in place with the OEM wires.
The run from the battery to under the driver seat is under 6 feet.
261251
As a side note, I was surprised to see what Mazda did to quiet the floor.
261252
261253
261254
J.
I'm going to be installing a fairly small 5 channel amp and had thought about using the stock battery fused post. Glad to hear it's a viable solution.
Man how's the Unity69s coming along? Dying to see what you come up with! Thought about them myself but still had shell shock from trying to mount Stevens Audio MB-8s unsuccessfully. What angle do you plan on mounting them? Diagonal?
Discussion Starter #27
Front speakers should be in by this weekend.
Ill make some mounting baffles using 1/2" hpde cutting boards and mount them with the stock bolts.
J.
Discussion Starter #28
Speakers are in.
261806
261807
261808
Old vs new.
261809
Traced the bose speaker into some hdpe cutting boards.
261810
Wired the speakers.
261811
In its new home.
261812
Put the oem grill on top and covered them with a dash mat.
261813
261814
J.
Discussion Starter #29
Door speakers
Used the oem baffle to trace it onto some hdpe cutting boards.
261815
261816
261817
261818
Got the wires into the door.
The molex plug was a lot of fun. Not.
261819
261820
Speaker in its new home.
261821
J.
Reactions: rton20s
Discussion Starter #30
Also got some work done on the IB wall.
Took the rear seats out.
261822
261823
261824
261825
Added some sound deadener and foam.
261826
261827
Made a template out of some insulation.
261828
Discussion Starter #31
Transfered the template to mdf
261829
Test fit.
261830
Circle jig to cut the mounting hole.
261831
Test fit 345.
261832
Temporary Wiring.
261833
Test fit 348.
261834
Stock carpet covering the wall.
261835
261836
Still need to fix it properly and carpet it.
J.
Discussion Starter #33
nice !!! always have digged your work!! how you like those 6/9 output?
Thanks.
Havent really tuned the system yet. Did T/A and Im using conservative crossover settings to break the speakers in (U3´s from 320 hz and up, U6x9´s from 320 to 80 hz and the sub from 80hz down all with LR 24 db).
Im waiting after break in to do some real tuning, but so far I like how it sounds.
I got to listen to other cars with the U6x9´s (including Ben´s Durango) and I really liked them.
J.
Nice I am just gonna have break down and drive some time to find some cars to listen to.
Very nice Build. :)
I also have 6x9 in my doors but they are OnCore C69 they unreal monsters !
Sent from my Pixel 4 XL using Tapatalk
Discussion Starter #36 (Edited)
Finished the IB wall.
First ran the speaker wire.
262344
262345
Then carpeted the wall.
262346
262347
262348
Wiring the sub.
262349
262350
All done.
262351
262352
All thats left to do is clean the wiring on the amp and tune.
J.
Nice install! My father had multiple M6's, including the 1st 626 in the early 80's.
Discussion Starter #38
Last piece of the puzzle is done.
Got the Amp/Processor wiring done.
262666
262667
The amp is under the drivers seat and you wouldnt hit it even with clown shoes.
262668
262669
262670
262671
262672
So that´s a wrap on this install.
I think I managed to meet my goals for the install.
You can open the hood, trunk, seat in any seat and you wouldnt notice theres an aftermarket system.
The only thing thats hints it, is the HU.
Now, just need to break the speakers in and start tuning.
J.
Great job! Looking forward to hearing your thoughts on the tuning process - what things worked, what things didn’t, what compromises had to be struck if any.
21 - 40 of 43 Posts
