I've got a 5 channel amp on order, so I took the opportunity yesterday to lay down my speaker cable and RCA's but I ran into a snag.
The rubber tubing between the car body and the car door is several inches higher on the door than on the car body, basically creating 2 elbows that the speaker wire will have to pass through - I tried slowly running some 16 gauge through it, but it wasn't stiff enough.
I tried pulling the tube's boot out at the door - I succeeded in doing that, but the boot itself is physically attached to the stock wiring, so that really didn't give me any room to straighten out the hose. It also means that taping the speaker wire to the stock wire and pulling isn't really much of an option.
Does anyone have any suggestions on how to run the wire? I've already got the wire laid through the rest of the car, so it's just a matter of running that one end into the door, and when the amp arrives, connecting it.
I've half considered drilling new holes in the door and car body, and installing my own tube, but if it's reasonably avoidable, that would be preferable. I probably won't be able to try again until next Saturday, assuming the weather isn't too frigid - the only other idea I can come up with is trying a relatively thin and flexible coat hangar, and easing it around the elbows in the hose.
Thanks for any ideas you can come up with!
Edit: The car is a 2002 Hyundai accent.
