Hey guys,
My drz just began to skip tonight for no apparent reason.
It started juddering as if you were fast forwarding, but it was going at a normal pace. It should be noted that the unit was quite warm and it started having this sporatic behavior in the latter part of a 2.5 hour trip. Could it have overheated causing the laser to have problems? could this beast be out of alignment?! I'm going to check tomorow morning when the unit is cold to recreate the problem. It was skipping on the last track ( on the outer edge of the disc so the disc is spinning the fastest ) Any advice?. I have never cleaned the lense but I'm cared to use a cleaning disc and less inclined to clean it manually, unless the top is easily popped and the lense right there to be accessed. I'm really upset here.
Thanks!
Thanks!
