Run the amp in 4 channel mode, otherwise there is no reason to have the 4 channel dsp. Wire 4 channels of rca cable from the dsp outputs to the 4 amp rca inputs, and wire the speakers individually to the 4 amp outputs. Make sure you have proper xovers set up in the dsp for the tweeters before you power them up. And don't use the factory speaker wires, run your own.
