Thanks for the input! I can see how much of a pain in the butt things can get with more complexity within a system but to me that's what's fun about it! I have a question for you about the biasing aspects of multiple amps and the surround sound decoding features that can be utilized from certain sound fields that can be created from such formats, utilizing a dsp for just simple tasks in the surround sound aspect of a system, not necessarily with basic stereo formats as that can be used differently of course.
not exactly sure what your asking , but I’ll take a stab at what I think you’re trying to say.
as far as like surround channels, I imagine you have a decoder and a upmixer upstream Somewhere…
The surround channels obviously are not as important as far as coherence goes , although still important that the signal integrity isn’t diminished….
like in 5.1 it’s the phase differences between L and R that tells the decoder what to send where
like left and right at the same time go to the center, and then a lot of them were like a 6040 split where as it pans it goes to left and right
and then the rears are left minus right and right minus left respectively between eachother
sub and center are pretty much the same thing.
Except below 200hz (if I remember my reading properly) the center is simple L+R (hence the .1)
discrete surround is a different critter, like 7.1 logic 7 where actual ambiant tracks are embedded and such…. (You won’t want me to explain it because I am not brushed up on that very well) I just know some of the newer stuff like atmos and logic seven do some pretty advanced things.
but I think that’s kind of the gist of what’s going on so that should answer your questions
once it’s decoded you can treat it like any other speaker and measure it and tune it any which way you want, as the phase of the L and R are mostly extracted and sent and are no longer so much dependent on L and R signals having coherence. But don’t mistake out for a free-for-all
It’s still very important to have your polarities proper and in time….
