1 - 12 of 12 Posts
Hey all. new to this forum. I have a Wrangler TJ that im going to be doing some more audio work on. Normally i use WranglerForum for my jeep stuff, but thought id get a better response about audio here! My idea is this: mount 2 downfiring 10" DVC Polk subs in a custom sealed enclosure behind my rear seats (trunk area). I wanted to put the amps (Alpine m500 and a 2 channel) below the enclosure mounted to the tub. I plan to mount the enclosure on sliders, so that i can pull the subs out if need be...any major concerns/issues with this? Ill try to find some pics to show you what i want to do.
Oh and im gonna wire them to get 4ohms load on the amp.
Other than the fact you'll only be running about 300 watts to your subs theres nothing wrong with your plan.
yeah i forgot to edit/update. i am picking up another m500 tomorrow. one sub per amp. now can use the 2 ohm load which is 500w RMS per sub/amp setup. will i need to seal off the subs from each other?
you don't need to seal the subs from one another.
Providing you can assure the voltage is identical.
But to play safe, I would recommend creating their own enclosures.
ok cool. i actually got the model that split it into 4 and had fuses inline. im going to run one power cable from battery into the trunk, then split it off from there. what gauge do i need for this? i have a 2x 20ft 8awg wire that i am currently using for the amps.
i ran 4 gauge from batt to distro block, then used 4 gauge for sub amp(its capable of 1200watts) and used 8 gauge for 4 channel amp
since u already have 2 runs of 8 gauge, maybe just get 4 for batt to block, then try 8 gauge from block to amps. i think 4 gauge might be recommended for the sub amps power, but not sure
thanks for the feedback. where do you guys get cabling from? all i can find are amp wiring kits in stores.
1 - 12 of 12 Posts
