Hi, i'm just wondering my upgrade path to add more amps. Currently i have a single 4 gauge from battery to distribution block then to two 8 gauge amps. Now my brother gave me his power hungry amp which requires 4 gauge power wire. Can i just add another 4 gauge power wire from battery to the same distribution block ?
If can, does my grounding need to be 2x of 4 gauge wire too ?
The inline fuse near the battery is to protect the wire if it were to short to ground, so you should fuse the appropriate amount for the wire. The recommended capacity for 4 gauge is about 125 amps so you can fuse each 4 gauge wire anywhere between the intended load (amp current rating) and the max current (125 amps).
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
