1 - 20 of 26 Posts
decided to go with the clarion setup I am working on .....I will need to test it to make sure it works...
$100 shipped
pm me if you got trades...I am not looking for any but I will think about it...no subs needed
Discussion Starter · #5 · (Edited)
tested it out..works fine looks great...if I dont sell it that will be fine...I like it enough that I couldnt decide on which deck to put in...I ended up installing an old school high end Clarion only because I have a cd changer for it coming and because the transport on it is smoother than the eclipse...
but the eclipse is a nice old deck ...it was a tough choice...
there is some slight wear on the volume knob rubber but other than that the deck is in excellent shape.
reads cd-rs no problem.....has bass / treble / mid tone controls...I dont know a lot about it as I just tested it...I didnt spend hours with it
happy fathers day bump
Discussion Starter · #7 ·
bump
Discussion Starter · #8 ·
bump
Discussion Starter · #9 ·
bump
Discussion Starter · #10 ·
bump
Discussion Starter · #11 ·
were arent talkin much money here
Discussion Starter · #12 ·
bump
Discussion Starter · #13 ·
$95....... lowered....thats it
Discussion Starter · #14 ·
Eclipse CD5441 Headunit Specs:
*ECLIPSE COMMANDER Ready
*ESN (ECLIPSE Security Network)
*High-Voltage (5V) & Low-Impedance (100W) Output
*The ECLIPSE Memory Buffer
*Integrated Optics Pick-Up Unit
*ECLIPSE STARTUNERV
24 Station Presets (18FM/6AM) & Preset Scan
*3 Pairs of RCA Pre-Amp Outputs
*Whole/Partial/None Display Selector
*Bass/Treble Memory for Each Source
*Non-Fading RCA Pre-Out *Terminals for Subwoofer
*Electronic Crossover Control
Flexible On-Board Memory
*Intelligent NOB & NOB Rotary Encoder
*Customizable Messages
*Auxiliary Input
*Head Unit Dimmer Setting
*2-Channel Selectable (IN/OUT) RCA Terminals for DSP Loop
*13W x 4 (2 - 20,000Hz, 0.8% THD, 4W)
*ECLIPSE LAN Advanced Data Link System
Discussion Starter · #15 ·
bump
Discussion Starter · #16 ·
BUMP
Discussion Starter · #17 ·
bump
Discussion Starter · #18 ·
bump
Discussion Starter · #19 ·
currently using this deck in car...not a bad deck at all....
trades? amps are about all I will ever need
Discussion Starter · #20 ·
bump
1 - 20 of 26 Posts
