Impressed with managing to soldier those surface mount components .
Interested with you impression of the pcm dad.
^^^ Broadly speaking, I agree. What I bolded in the quote is my biggest concern. Basically what I'm working towards is band-limited impulse response correction. And it's not clear to me that anything other than arbitrary magnitude, arbitrary phase (AMAP) filters can do the job in general. In fact, I often wonder if problems encountered while equalizing with equipment without AMAP capabilities are sometimes erroneously ascribed to causes other than what I suspect is the most likely root cause -- lack of equipment capability.... getting the phase corrected in the pre-amp and still not be able to control phase at the listening position, due to all the various resonant frequency tone generators that are hiding in plain sight.
I think a lot of people seek out the front end "fix" for the muddy mid bass, the parametric, the auto tune, and various wave generation/synth products, and as you ramp up volume you excite different panels at different volume levels, and it makes you think it's intermodulation, or it's transient filters ringing, but it's probably just the resonating car.
Alchohol affects your typing? Have a few too many Mikes hard lemonade? :laugh:invlearbing
I think Jon W.'s magic bus relies on passive absorbing of long-duration resonant modes using helmholtz tuned traps that are the frequency of the sides and top of his van, and the bottom probably doesn't resonate much due to the heavy ass sub box.^^^ Broadly speaking, I agree. What I bolded in the quote is my biggest concern. Basically what I'm working towards is band-limited impulse response correction. And it's not clear to me that anything other than arbitrary magnitude, arbitrary phase (AMAP) filters can do the job in general. In fact, I often wonder if problems encountered while equalizing with equipment without AMAP capabilities are sometimes erroneously ascribed to causes other than what I suspect is the most likely root cause -- lack of equipment capability.
I won't be using auto-tune, and I'm aware of the resonant issue, so I suspect the difficulty will boil down to whether I can detect the resonances in an impulse or frequency response, and if so, whether I can effectively remove their signatures from the measured responses.
I do intend to assess linearity by taking impulse measurements at multiple amplitudes. I don't think things will be easy, but I'd like to try. We'll have to see what happens when I get time to work on the car again (really busy right now).
I soldered up some hardware to implement FIR filters as described on DIYMA here. That hardware is centered around Analog Devices' (AD) ADAU1442 IC, which can be rapidly programmed with AD's graphical development software called SigmaStudio. For automated control of sound measurement devices -- in my case a Cross-Spectrum Labs calibrated MIC with an M-Audio Fast Track -- and also for design & analysis of FIR filters, I use MATLAB from Mathworks.Still a little drunk but how exactly did you make the fir filters? I'd be very interested invlearbing how to do that
I used Wolfson's WM8524's to drive the analogue (as they say) outputs (4) of the signal processor I built. The WM8524's sounded fine to me. I've only heard PCM5102A's on my subwoofer or on headphones during circuit testing (and they sounded fine there), but on paper the PCM5102A outspecs the WM8524 and is a similar class of DAC implementation (ground centered output with integrated charge pump).Interested with you impression of the pcm dad
^^^ That is a dense post. For now, I'll simply say thank you for communicating all those ideas.I think Jon W.'s magic bus relies on passive absorbing of long-duration resonant modes using helmholtz tuned traps that are the frequency of the sides and top of his van, and the bottom probably doesn't resonate much due to the heavy ass sub box.
If you can get the major panels of your vehicle to stop their reverb using active cancellation with DSP, that would be another way.
The recent spate of OEM's using active noise control has made this avenue much more approachable since the homework built into such a system is already done, analyzing the settings of those DSP amplifiers or servo, would allow you to do corrections the same way using your home-brew DSP FIR filters.
Hard to say if you could apply the technology for reducing tire rumble, effectively to reducing a car's major resonant nodes.
I would think so, and starting off with a known quantity like an OEM noise control system to run with, might be much simpler than it would appear. Thankfully I'm not able to do the work you're doing, or I might have spent the time trying it myself.
the problem as I see it is the transmission of sound through various amplitudes, differs from the simple correction values applied for DSP filters like floor bounce or bass contouring, there may be some dynamic equalization required.
maybe just install a Bose, haha...
interesting, pretty much what I was saying. Bose uses a loudness contour called dynamic EQ, that is engineered into the specific set of driver/sub combination for use in the home. I think there's a "test" CD, I forget...^^^ That is a dense post. For now, I'll simply say thank you for communicating all those ideas.
For a first pass with the new equipment, I don't intend to use DSP to actively cancel panel resonances or road noise. Instead, I'm hoping to be able to subtract resonant effects from response measurements and correct what remains. Presumably, the majority of what remains will be visible as peaks and valleys in the frequency magnitude response, and I would expect those peaks and troughs would be a consequence of cabin geometry (we shall see). Rather than correcting those distortions by adding complementary peaks and troughs, though -- i.e. by traditional "EQ-ing" -- I instead intend to remove those distortions by correcting the impulse response over the lower frequencies. In other words, I intend to correct both the magnitude and phase of the frequency response, not just the magnitude. I suspect that the approach I am taking has not been traditionally adopted in the past because it requires arbitrary-phase, arbitrary-magnitude filtering, which is best-implemented with digital FIR filters. I think, however, that many of the new-ish room correction devices -- as well as something that has been available for several years for car audio from Alpine -- already perform impulse response correction of some form. I'd just like to try it myself.
Ideally, I'd like to use mechanical, as opposed to acoustical, means to overcome resonances -- although I realize that there is a low likelihood of taming all resonances mechanically. (I've already been trying for years and still working on it).
