Would you like to see Second Skin sell a skid & scratch resistant enclosure coating?
  • Yes - This would be a great idea!
    Votes: 157 54.7%
  • Maybe - I need more info
    Votes: 72 25.1%
  • Nope - Carpet and regular paint both work just fine
    Votes: 55 19.2%
  • Leaving comments below
    Votes: 3 1.0%
1 - 20 of 81 Posts
We (Second Skin) have almost developed an acrylic coating that sticks to wood like crazy.
Very similar to our noise coating Spectrum but without all the stuff that makes spectrum adhere well to metal, rustproof and such.
So instead of carpeting your sub enclosure, you could simply paint on this durable liner. It is something like a bed liner but not as glossy; a bit more flat but with good skid and mar resistance. Something you can clean with a wet rag that won't get scratched up.
We can add an agent to the mixture to make it self leveling too so it will always be smooth no matter how you paint it on, or we can give it a bit of a texture.
Very exciting stuff. Is this something you guys would like to have available?
ANT
Re: Enclosure cover - Would you guys like to see a druable coating for kick pods & bo
sounds like a cool product, would it be black or grey?
Right now it is flat black, but we could gloss it, or make it grey as well.
Any color really , but every batch we make is at least 200 gallons so it is much easier to keep it grey & black
ANT
Ide buy some. I just made another home theatre box and bought some el' cheapo "bed liner" spray. Turned out pretty much flat black but just looks like paint.
Personally, I would like to see some texture in the product.
For texture we can add
crumb rubber from tires.
recycled tennis ball bits
80 mesh rubber powder
Ceramic spheres
Solid or hollow glass spheres
a few other things as well.
I will have to play with it some..
Can't say I'd be interested. I'm sure others would be though.
I have a couple questions if I may I have another idea for it:
Does it have any sound deadening properties ? (May be a stupid question)
Would it help to stengthen an enclosure ?
What can we expect for thickness on single coats ?
I would like to see u sell it just flat black without an texture and give us a bag of texture to mix before application. I can think of a ton of other applications for it. But I we are getting ready for a Chassis build on a rat rod and want something to coat the chassis in thats durable but not like undercoating but that we could apply in thin coats like primer.
Something like this but a driver:
Land vehicle Vehicle Car Vintage car Motor vehicle
NOT TRY TO GO OFF TOPIC SORRY ! :D
My first thought was: why?
Unless it was less expensive than covering a box with the typical carpet, I doubt I would bother with it.
Then again, I can image that it would be a great DIY method of finishing fiberglass sub enclosures or speaker pods if it could be textured to match vehicle interior panels.
So really, I think it would be a cool alternative to have for custom applications more than anything.
Discussion Starter · #9 ·
The total thickness will only be about 20 mils so sound deadening will be kind of limited. Not really enough material on the wood to reduce resonance. Not sure how well 40 or 60 mils would do. There might be some mud cracking at that thickness, unless multiple thin coats were allplied and allowed to dry. The coating can go on the inside and outside of the box though. IT will do a good job at sealing it up, but in a properly built box, there should not be any leakage issues anyway.
For the rat rod, I would look into the regular Spectrum coating, which will do an awesome job protecting against rust and vibrations.
ANT
Thanks ANT
spellcheck that title
Re: Enclosure cover - Would you guys like to see a durable coating for kick pods & bo
I think it would be great, I've been wondering what to use on my HT cabinets.
I think the main question I have is cost?
There are several forms of bed liner out there that are reasonably priced. I have used Herculiner, Durocoat and a generic one I can't think of. The durocoat was 50 bucks for a half gallon kit. The Herculiner was 80 bucks with rubber bits. I prefer it to carpet as it seals the MDF. Well and I suck at carpeting.
I think it sounds like a good idea. I also like the tire bits idea for the texture, Do you have any pictures of it on a box yet?
If it's really durable lie other stuff on the pro market I'd be ALL ABOUT IT for my PA boxes, the carpet from the 80's is shot bad. I'd likely try it on my sub boxes first because they don't have flyware on them to remove, etc.
This sounds great!! Was just about to repaint my box with more bed liner, guess I will wait it out in hopes this stuff comes out soon
Discussion Starter · #17 ·
Nope
No pics yet.
The formula is pretty much done though. Just messing with the texture.
ANT
Any chance of getting a test gallon? I have a huge 5.2 cu ft box that I would love to try it on. Sorry, I'm sure you guys are tired of questions like this but I am just real excited for this stuff. :D
I'd love it if it were pretty reasonable in cost. I prefer using a bedliner type of product on my boxes because A) It's durable B) easy to do C) I suck at carpeting.
I was just thinking about this today. I was looking for a textured bed liner earlier so this would be perfect.
1 - 20 of 81 Posts
