Product Brand & Model: Hybrid audio Technologies Legatia L4SE "Carbon"
Condition of all items: New
Total Price: $385.00 - via paypal
Shipping Terms: Free to the lower 48 states. If international, contact first for actual cost.
Pictures: Attached
Specifications
Overall Diameter 118 mm (4.65-inch)
Mounting Depth 42 mm
Mounting Hole 94.5 mm
Recommended Minimum Crossover Frequency 150 Hz at 24 dB/octave highpass
Pmax (With Recommended Minimum Crossover) 150 watts
Frequency Range 135 Hz – 7,500 Hz, +/- 3 dB
Sensitivity 91 dB at 2.83V/1meter
Voice Coil Diameter 25.55 mm (1-inch)
Impedance 4
Fs 135 Hz (free air)
Qms 3.353
Qes 0.789
Qts 0.639
Vas 1.3 L
Attributes
The Legatia L4SE is a 118mm (4.65-inch) midbass driver to compliment both two-way and three-way system designs, where a shallow-depth, long-throw, small-format midbass is required. The following are the L4SE Carbon’s design attributes:
Design Considerations
The Legatia SE Carbon-series component speakers are electrodynamic drivers that are comprised of a diaphragm that is set in motion by a motor system that has both electrical and mechanical components. The Special Edition Carbon midbass designs boast several key elements which enhance the driver’s performance in vehicle-specific applications, notably applications which require a shallow-depth midbass driver, such as typically found in numerous German-manufactured automobiles (Audi, BMW, Porsche, and etc.). Likewise, the Carbon midbass’ can be used at the enduser’s discretion in a variety of automobile settings where a shallow-profile, long-throw midbass is required. The Legatia SE Carbon midbass differ vastly from the Legatia SE-series wide-bandwidth drivers, as follows:
Pictures: Attached
Specifications
Impedance 4
Qms 3.353
Qes 0.789
Qts 0.639
Vas 1.3 L
Attributes
