Soundqubed Q4.120
BNIB
$200
Buyer pays
Has been sitting in my closet for 6 months waiting to be installed. I've since decided to go another route as this is WAY too much for the speakers I chose. Will come with everything from factory. I've bought from AQ/SQ for years and never been disappointed. They actually stopped production of the Q4.120 in place of a smaller Q4.90 which will better suite my power needs... Although even that is a bit much :/ Anywho, here is some BS I found on their website to better explain how wicked this 4channel is
High power 4 channel class A/B output section.
The 120.4 features variable high and low pass filters that can also be used in a band pass/full range configuration.
Remote gain control knob w/ clipping indicator
Specifications
Model Q4-120
Dimensions 15.75" x 9"
Input Sensitivity 8V~0.2V
Low Pass Filter 50Hz ~ 5kHz
High Pass Filter 20Hz ~ 5kHz
Crossover HPF/FULL/LP-BP
Remote Gain Control Included
Clipping Display Led Yes
Signal to Noise Ratio 105dB
Damping Factor 200 <
Bass Boost @45Hz 0~18dB
External Fuse Rating 40A x 2 pcs
4 ohm power @ 14V 120Wx4
2 ohm power @ 14V 170Wx4
4 ohm mono power @ 14V 340Wx2
Power and Ground Inputs 4ga
Soundqubed Q4.120
BNIB
$200
Buyer pays
Specifications
Model Q4-120
