1 - 10 of 10 Posts
· Registered
Any ideas or help with designing a fake floor and amp rack/area in a Honda hatchback 97?
Rear seats I'm pulling out, I'm thinking a fake floor (plywood/mdf) in hatch area, where I will be putting one 15 inch sub and enclosure along with a rear speaker box housing 2 10 inch drivers and some tweeters, I need enough space for a kinetik hc 2400 or two hc800 maybe in spare tire well, amps might go where rear seats once were, just trying to draw up a rough game plan here
How would I keep the fake floor in place?
Recommendations leaving amps in open air or making an enclosure with fans constantly flowing fresh air? (Currently car has no a/c)
My goal is to put a clean and tidy setup, not show quality.
Thanks appreciate any input
· Registered
Tons of ideas... I would first encourage you to search the build log section for ideas... then maybe post some pics of things you liked and we could build off of that and give you advice on how to create a similar install.
· Registered
2000 Ford Ranger XLT
I used the carpet to trace put a template. Idk of that helps you
You could just make it wide enough that it pushes out when assembled and braces itself that way but I will always suggest securing it with existing bolts or something. Are you trying to keep your spare? Will you fiberglass for your enclosure?
· Registered
Discussion Starter · #9 ·
No spare tire...was trying to fit battery(s) in there, no I did not plan on fiberglassing my enclosures, I will try to get you guys some pictures of my speaker box, I want to be able to make my amps and speaker box easily removable when I'm not using them
1 - 10 of 10 Posts
