1 - 20 of 115 Posts
Hi everyone,
Now is time to present my project :D
Few pictures when car has been stock:
Few new badges:
First Im buy new complete suspension and lower car for 5cm.
Discussion Starter · #2 ·
Then Im build my first CARPC with next components:
Jetway 7F2WE-1G5-OC 1.5GHz
M2-ATX 6-24V DC/DC (160 Watt)
Adapter HDD 2.5" to 3.5"
2,5" HDD
RAM 1024MB DDR-II 533MHz CL4
VoomPC [Black Edition]
BU353 USB GPS (Sirf III)
USB Bluetooth Jabra A320s
USB Wireless card with external 6dB antenna
7" LCD In-Dash Touchscreen (K90)120GB
Installing carpc into car:
VGA cable :D
USB HUB with WLAN, BT, TS & GPS
second USB HUB
Radio & LCD:
Then Im sell this CARPC and start build new INDASH CARPC :)
First Im buy few new things.
OBD Pro:
Microphone:
Then Im buy components:
-MainBoard: VIA PICO PX 10000G Pico-ITX
-Ram A-DATA SO DDR2 1GB 533MHz
-HDD 2.5" WD 1600BEVS S-ATA
-Adapter SATA-HDD 2.5" to SATA-MB and Power
-Power Suply M2-ATX 6-24V DC/DC (160 Watt)
-Monitor LCD TS CTF800
-GPS OEM GlobalSat ET-332
-TPMS
Then Im start making mask for LCD:
and building TPMS:
And then Im find first little problem. I need case for carpc. hmmmmmmmmm where can I get it? Maybe build it from old PC case? no to hard :D And Im find old radio from mothers stilo... Looks nice maybe I can use it...
Time to destroy it :D
And with new mask for LCD:
On this picture you can see MB, HDD & GPS:
Discussion Starter · #7 ·
then Im stop my project because pico MB doesn't support S3 power state and Im sell it.
Motherboard VIA EPIA NX15000G
then Im must find best positions for power supply, HDD and motherboard:
Discussion Starter · #8 ·
And Im continue with my project. Im build TTL->USB module for my GPS globalsat ET332 module.
First TTL->RS232:
And then real board TTL->USB:
Mounting GPS and modul in case:
Preparing for putting case together:
Wow, nice coversion of the factory double-din. Keep the pictures coming, it's looking good.
Discussion Starter · #10 ·
USB connector, GPS connector and Audio connectors:
Finished case:
So there is preparing for update audio system.
In original place in door will be Hertz Mille ML165:
Discussion Starter · #12 ·
Block for + power cable. in: 2x 50mm2 out: 3x35mm2 + 3x10mm2:
Buttyflex for damping door:
Im continue with my friend installing components in my car. First we are put down all things from door and put Buttyflex into it.
Discussion Starter · #13 ·
Then Im trough original door connector put two cables one 2.5mm2 for ML165 and 1.5mm2 for tweeter.
Installing tweeter in original position:
Then Im continue with installing:
Discussion Starter · #14 ·
Test how look tweeter in original position:
Completed door:
And 50mm2 cable:
Im receive first amplifier Audison LRx4.1K for front system:
And free t-shirt:
Discussion Starter · #15 ·
Amplifier Audison LRx4.1K:
Amplifier for sub. Audison VRx1.500 + SPL TUNE KIT :D
2400W RMS @ 1ohm (AB class)
panels for tw(not completed):
Discussion Starter · #16 ·
Place for headunit:
And two subwoofer SPL Dynamics XTR12D4 (12" )
End panels for tw(Not yet finished):
Discussion Starter · #17 ·
Panels for tw again...
Panels for tw almost finished:
And working plugin for Centrafuse for TPMS device
Radio installed:
Cables for CarPC
Discussion Starter · #20 ·
Something new:
Before:
After:
Test box for subs:
I will build new one(nicer one) :D
Im buy new AGM battery for car :D
Then Im connect battery with my sistem...
1 - 20 of 115 Posts
