Please bear with me as this is my first Fiberglass enclosure.
the red box will be recessed into the door 2.5" after i cut some of the door skin out of the way. I will also have to cut thru some of the bracing, but will find some way to reinforce those areas. I am hoping to get 1/4" thick fiberglass.
The blue box is 11" x 17" x 2.5" outside dimension. I can make that out of either 3/8" MDF or I guess I could fiberglass that as well. I would like to keep weight down.
Hopefully the overall volume will be .35 cubic feet for a Alpine SWR-8D2.
My question is how to outline the inside of the opening I am cutting out so that I can lay the fiberglass matting and have it keep the form?
Also, should I use 3/8" MDF for the outside box and attach it to the fiberglas mold, or should I build a frame and fiberglass the outside box as well?
What suggestion would you have for attaching this box to the door frame?
Any other suggestions before I take on this build?
